Joined: 11/03/2010 Posts: 234 Points: 734 Location: Whelpley Hill, Chesham
Thank you for looking in and your comments. I cannot claim a lot of skill on my part to assemble this model as all parts fit very well straight from the box. I am enjoying it never the less and the end product should be magnificent. Issue 6 is the air box and the engine block and all very well detailed, you need some good tweezers and don't drop anything because a magnet won't find it. Alec alemo attached the following image(s): Built: Bluenose, Arab Dhow, HMS Bounty, Hummer H1, D51, Spitfire,E type Jaguar. In Progress: HMS Victory, , Yamaha YZR-M1
Adapt, improvise, overcome.
Glad to hear you are enjoying the build Al
 All looking good and nice work Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,277 Points: 22,138 Location: Northamptonshire, England
Nice work, looking good. Mark Regards Markwarren (Mark) Admin
Hi everyone, thanks for the comments. Issue no 7 Stage 25 step 3 and 4. Fixing cylinder block to engine block. I found that following the instructions there appeared to be a screw missing (I don't think it's me) and instead of the usual single spare screw there were two spares. With only two screws fitted to one side only, it tended to gap on the other side. This is my opinion, feel free to correct me if I'm wrong. Alec alemo attached the following image(s): Built: Bluenose, Arab Dhow, HMS Bounty, Hummer H1, D51, Spitfire,E type Jaguar. In Progress: HMS Victory, , Yamaha YZR-M1
Hi Alec, You might just want to check if it's seated properly, unless it's just the angle of the photo? Have you tried taking it apart to see if you can get the block square to the head? Do the holes line up correctly?
Regards Gray
Hi Gray, Holes are aligned correctly, outside of casing absoluteley in line, without the additional screw it was possible to open a gap on the opposite side to the two screws shown in the instructions. Why else is the hole there but to take a third screw? I'm sure that it's a missing instruction. Alec Built: Bluenose, Arab Dhow, HMS Bounty, Hummer H1, D51, Spitfire,E type Jaguar. In Progress: HMS Victory, , Yamaha YZR-M1
Hi Alec I think it's the light casting a shadow below your exhaust ports  . If it all sits flush, then you shouldn't have any problems going forward. Looking at step 5 of that same stage, the screw should be used then, if i'm reading it right. Having checked mine i can't see a screw in that slot either, but everything is sitting tight and square. Agree, can't think why there is no screw in that hole Not sure if you can make it out in the photo. Hope that helps. I still think your making a good job of it though Cheers Gray CaptnBirdseye attached the following image(s):
Hi Everybody, At last pack eight arrived, it consists of more details to the power unit. One small detail that I enjoyed is the gear change lever, once installed and the sump fitted with the switches installed operation of the gear change lever gives a nice click as if something is actually happening. (I'm easily pleased). All components fitted as they should and now I go and do something else for a month "yes dear I will do it now" Alec File Attachment(s): alemo attached the following image(s): Built: Bluenose, Arab Dhow, HMS Bounty, Hummer H1, D51, Spitfire,E type Jaguar. In Progress: HMS Victory, , Yamaha YZR-M1
sorry one picture to big alemo attached the following image(s): Built: Bluenose, Arab Dhow, HMS Bounty, Hummer H1, D51, Spitfire,E type Jaguar. In Progress: HMS Victory, , Yamaha YZR-M1
 Good news with the delivery, and great update Alec, Looks good
Hi Everybody, This is pack 9. More additions to the power unit. Not a screw in sight. I found that some of the push fit pins were a bit too tight and would not allow the components to fit fully home so finished up removing the paint from them to get a good fit and then used a little adhesive to ensure they stayed in place. This is a very nicely detailed model that is a pleasure to assemble. Alec alemo attached the following image(s): Built: Bluenose, Arab Dhow, HMS Bounty, Hummer H1, D51, Spitfire,E type Jaguar. In Progress: HMS Victory, , Yamaha YZR-M1
 Another great update Alec  That engine and clutch assembly sure does look sweet Cheers Gray
Hi everybody, Issue 10: stages 36 to 39 manifolds and throttle bodies, interior parts for the air box, and the rear shock absorber. Alec alemo attached the following image(s): Built: Bluenose, Arab Dhow, HMS Bounty, Hummer H1, D51, Spitfire,E type Jaguar. In Progress: HMS Victory, , Yamaha YZR-M1
Looking good Alec, coming together very nicely.... Regards Alan
 Great update Alec
Hello everybody, Pack 11, stages 40 - 43 incl. Air Reservoir, Frames and Cross Members. Right hand frame is not screwed down as more work to be done in next stages. Feels like progress now frames are included, (nice lumps of metal). Alec alemo attached the following image(s): Built: Bluenose, Arab Dhow, HMS Bounty, Hummer H1, D51, Spitfire,E type Jaguar. In Progress: HMS Victory, , Yamaha YZR-M1
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,703 Points: 17,261 Location: ipswich
Looking very impressive now.
 Coming together well now, Alec
Nice work. Following with interest. Andy.
