80 Pages «<4142434445>»
Sticky Wickett
#841 Posted : 02 April 2019 16:45:16
BigGrin All looking good Phil and nice workDrool Drool Cool
Thank you Andy!Cool
Phil W.
Sticky Wickett
#842 Posted : 02 April 2019 16:46:19
Markwarren wrote:
Excellent work as usual Phil Love
Thank you Mark!Cool
Phil W.
Kev the Modeller
#843 Posted : 02 April 2019 20:51:05
Some more fine detail being added here Phil, those guns are looking good and will certainly come to life when the paint is applied, well done. ThumpUp
Per Ardua Ad Astra
Garth
#844 Posted : 03 April 2019 06:41:15
Hi Phil,
Great update again. Those guns look amazing!!!
Kind regards,
Garth
"Measure twice, cut once!!!"
Finished!!! HMS Victory,
Current build: Black Pearl.
Wish list: USS Constitution.
Sticky Wickett
#845 Posted : 03 April 2019 22:00:23
Thank you very much Kev. Hopefully not too long now before they get painted!Cool
Phil W.
Sticky Wickett
#846 Posted : 03 April 2019 22:01:06
Garth wrote:
Hi Phil,
Kind regards,
Garth
Thank you very much Garth! Appreciated.Cool
Phil W.
Sticky Wickett
#847 Posted : 03 April 2019 22:06:15
This week continues with the building and modifying of the 2.0cm Flak 38 double barrelled guns that will locate on the top deck of the conning tower.
The next step was to make the gun operators handles. Using 0.8mm diameter plastic rod, I bent each piece around a needle file before clamping it to the file and immersing in hot water to form the shape.
The attached photo shows the completed handles fixed to the guns with the 3D printed original next to them.
Sticky Wickett
#848 Posted : 03 April 2019 22:07:20
I then added more detail using 1.0mm diameter brass rod to simulate levers.
Sticky Wickett
#849 Posted : 03 April 2019 22:10:21
The next step was the tricky part; fixing the a-frames that support the guns onto their mounts.Blink Using plastic rod and 0.5mm diameter brass rod to act as securing pins, i finally got the guns mounted, hinges working.
Sticky Wickett
#850 Posted : 03 April 2019 22:11:09
Looking from a different angle.
Sticky Wickett
#851 Posted : 03 April 2019 22:12:06
From above.
Sticky Wickett
#852 Posted : 03 April 2019 22:14:16
That concludes this weeks post. One more evening next week will see these guns completed and then it's onto the guard rails!Blink
Thanks for looking in, have a great weekend and happy modelling!Cool BigGrin
Phil W.
CaptnBirdseye
#853 Posted : 04 April 2019 07:56:13
Rank: Superelite
Drool Love Drool WOW ThumpUp
Truly a labour of love! They look superb
All of us with this kit will be putting our orders in later BigGrin LOL BigGrin
Regards Gray
DaDokta
#854 Posted : 04 April 2019 09:14:38
Incredible as always! Those guns look so good!
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
Sticky Wickett
#855 Posted : 04 April 2019 09:18:35
Regards Gray
Thank you very much Gray!Cool Two weeks of fiddly work plus one more evening next week will see these guns complete!
Orders?!!!!LOL LOL LOL Flapper Flapper Flapper
Phil W.
#856 Posted : 04 April 2019 10:49:18
Very impressive work, loving it....Drool Drool
Sticky Wickett
#857 Posted : 11 April 2019 21:56:55
Thanks very mcuh Alan!BigGrin Cool
Phil W.
Sticky Wickett
#858 Posted : 11 April 2019 21:59:31
This weeks update sees the completion of the two 2.0cm, double-barrelled Flak 38 guns for the upper deck of the conning tower and making a start on the guard rails for the lower deck.
The attached photo shows the completed guns; handwheels and counter weights attached.
Sticky Wickett
#859 Posted : 11 April 2019 22:06:50
Next up; the guard rails!
I started by making 17 guard rail supports. The guard rails slot into these supports and are positioned around the perimeter of the lower deck.
I began by drilling out 1.5mm x 1.0mm strip with a 0.8mm diameter drill to accept the brass tube that will make up the guard rails. 17 holes in total. I then cut each side of the holes and filed these to clean them up. To prevent the brass tube from sliding all the way through, i then glued each individual square to a 1.5mm x 1.5mm strip and then filed and cleaned up each piece.
Sticky Wickett
#860 Posted : 11 April 2019 22:07:24
The first guard rail support fixed in place.
This page was generated in 0.520 seconds.
