This looks like a lot of sanding ahead!Greetings, Walter
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,282 Points: 22,153 Location: Northamptonshire, England
Looking excellent, that will rub down very nicely. Mark Regards Markwarren (Mark) Admin
Making good progress Mark, look forward to seeing how she looks after the sanding is done.... hope you have a good strong sanding arm.... Regards Alan
Joined: 11/04/2018 Posts: 37 Points: 123 Location: Michigan
WOW that was a lot of filling and sanding. I lost a lot of the planking definition in the lower hull but i did not have much choice. It is not as good as the other builds I have been following. I hoping for what you call a 5-10 it looks great from 5 to 10 feet away.. FightingWillie attached the following image(s):
Looks pretty good from here. Well done.
Planking looking good. Well done. Kind regards, Garth "Measure twice, cut once!!!" Finished!!! HMS Victory, Current build: Black Pearl. On hold: Bismarck, Golden Hind, Flying Scotsman, Victory Cross Section, SOTS, Tiger 1. Wish list: USS Constitution.
Nice update!Greetings, Walter
Good steady progress.... Regards Alan
Joined: 10/03/2016 Posts: 74 Points: 225 Location: Mirfield West Yorkshire
Looking good ,we’ll done.
The latest update on the HMS Victory completed stage 44. I have gotten the rear gallery , wales , stem supports head deck and cut out in the wales so I can install the decorative pieces later . I am going to stop here to copper plate the hull and I have a few questions. I have seen video showing people using CA glue but I have read that I should use contact cement, which is better? CA is straight forward, but contact cement I have never used before. My biggest concerns with contact cement is do you have to remove old contact cement before you start a new build session on the model and the tiles that you have already coated with cement? FightingWillie attached the following image(s):
You have moved on very well with this one. Its really looking the part. When i ever get to doing mine i will be using one of the "flexible" superglues. Contact adhesive depending on what you buy can be awkward as it has a tendancy to string when being used. You can get non stringing gel versions and here is an ebay item code that might be of interest 271816733975. Code for a point of interest and not an endorsement of the seller by the way. If you look up non dtring contact adhesive there are a number of brands but some come in tins that would last a lifetime and beyond. I am sure you will get some other views on what people have used but for me it will be the superglue route as that seems a little more previse to me. Tony Happy Modelling
Looking very nice, excellent work. Mark Regards Markwarren (Mark) Admin
It has been a while since I updated my build. I have working on the copper tile on and off all summer. It looking OK, but gluing those tile on was tedious and the glue made mess  . Although now I am on to stage 45 and I get to touch wood again
I have not posted in awhile, it look like I missed posting some pictures FightingWillie attached the following image(s):
Here are some latest pic of my ship HMS Victory I have reached the half way point. So it is time to put the hull under raps and start to work on the mast and yards arms. FightingWillie attached the following image(s):
Neat and tidy work there. Very well done.
Continue like this and you'll end up with one beautiful build, one you can display with pride..... looking great..... Regards Alan
Here is an update , I have completed the main and fore mast. I am going to jump around a bit and not follow the instructions. I want to complete the mizzen mast and all the yards before going back to the hull. I don't quite like the way the wales came out around were the wiggles will be installed. FightingWillie attached the following image(s):
Joined: 26/06/2013 Posts: 174 Points: 490 Location: Lancaster, PA
That is looking good! Christopher Current builds: HMS Victory Black Pearl
Builds on hold: Millennum Falcon USS Constellation
Future Builds: Hanse Kogge (14th C) Mary Rose (16th C)
Looking goog You really appreciate the size of the Model once you start fitting the masts. I also made the masts, yards & bowsprit at the same time. Kind regards, Garth "Measure twice, cut once!!!" Finished!!! HMS Victory, Current build: Black Pearl. On hold: Bismarck, Golden Hind, Flying Scotsman, Victory Cross Section, SOTS, Tiger 1. Wish list: USS Constitution.
