12 Pages «<7891011>»
Lancia Delta Martini WRC 1991 + Lancia Delta Test car 1991 Hachette 1/8 Options
frah2o
#161 Posted : 04 April 2019 10:01:37
I started the job on inside details: i completed the idraulic brake and handbrake lines with some extras
frah2o
#162 Posted : 04 April 2019 10:02:41
Another work on inside with the add of exsthinguisher system and kevlar carpet.
frah2o
#163 Posted : 06 April 2019 07:17:21
Continuing with internal detail.
I add extra transkit of headset and intercom.
After painting it with references color, i add some neoprene to simulate the padding.
Some few details and finally i will start with the final work on body shell.
#164 Posted : 06 April 2019 08:10:30
Stunning work, breathtaking.Love Love
Kev the Modeller
#165 Posted : 06 April 2019 10:59:46
Very nice work indeed Francesco, this is a great build and your scratchbuilding is brilliant, love those headsets! Well done. Drool ThumpUp
Per Ardua Ad Astra
frah2o
#166 Posted : 08 April 2019 08:21:45
Thanks mark, i always follow your fantastic work. Laugh
Thanks too much Kev. This couple of delta is my first test to know my level with scratch. I hope to made a satisfy job.
Yesterday i think to finished the last engine details.
Just a little detail and seats and finally i can start the last big section of the building. the bodyshell
Here my last work on top mount absorber and the final fitting of intercooler duct
frah2o
#167 Posted : 12 April 2019 08:53:35
I start the job on roof struts bar.
I made some work to correct the bars and the mistake on roof vent.
frah2o
#168 Posted : 12 April 2019 08:58:18
Some final work on last inner and underside detail.
I worked on tailpipe, fuel filler and i self made the horn switch near on the foot rest on navigator side
I studied the refernces photo for the roof flap for the roof vent. In Montecarlo 91 was different of the Hachette proposal.
So i clodes the fitting hole for thr wrong flap
I also continued with work on roof struts
frah2o
#169 Posted : 12 April 2019 09:00:36
Final work and fitting with fuel filler
Final fitting and wheatering on tailpipe with add of weld line
I fitted the horn switch and i remade the new and correct roof flap
Finally i made the new central pillars.
Kev the Modeller
#170 Posted : 14 April 2019 11:03:26
Superb detailing Francesco, your model looks very realistic. You are a master of car modelling!
Very well done. Drool ThumpUp
Per Ardua Ad Astra
frah2o
#171 Posted : 02 May 2019 10:58:54
Thanks to much Kev Blushing ....10 holidays days, it's time to update this topic.
frah2o
#172 Posted : 02 May 2019 11:01:55
I remade the roof vent with new scratch panel.
I changed the screw with new bolts
With milliput i made the new "coating" of the rear inside mudguards of the bodyshell
After masking, i painted the inside of bodyshell with correct alluminium paint
frah2o
#173 Posted : 02 May 2019 11:03:49
After the inside alu painting, i repainted in matt black the B pillars with matt black
I made the new gasket door trim with vinyl tape.
frah2o
#174 Posted : 02 May 2019 11:09:53
I made the new gasket trim for the trunk
I painted in alu the inside of fuel filler
frah2o
#175 Posted : 02 May 2019 11:12:39
I revisited the rear light, the orginal kit are too much shiny.
I reworked the C pillars
Finally i fitted the repainted fuel filler
frah2o
#176 Posted : 02 May 2019 11:14:28
I fitted the new kevlar decal on roof vent an the on the inside of fuel cap
frah2o
#177 Posted : 02 May 2019 11:36:38
I removed the Martini livery from the future Delta test.
I started the clear coating of my Martini
frah2o
#178 Posted : 02 May 2019 11:37:46
Some other job of clear coating on my Martini bodyshell
frah2o
#179 Posted : 02 May 2019 11:39:50
Some work on rear trunk badge.
I self made the license plate lights
I erased the wrong license plate for new correct of Montecarlo 1991
frah2o
#180 Posted : 02 May 2019 11:42:28
I fitted the new correct trunk badge
I worked on the inside trunk structur
I full white resprayed the inside of the trunk
I add the heatshield on the trunk
I repainted in alu and add neoprene on front hood bar
Guest (11)
This page was generated in 0.462 seconds.
