lining of gun ports Options
ronald305
#1 Posted : 09 April 2019 16:55:58
hello there
this is may be a silly question but does it matter if one side is done first then the other thank you
Ronald
#2 Posted : 09 April 2019 17:55:34
Ronald
No it does not.
This only applies to planking were you need to apply one plank port side and one starboard side each time to prevent any twisting of the hull.
You will be ok lining all of the port or starboard side with no issues.
Kind regards
Tony
ronald305
#3 Posted : 12 April 2019 02:37:27
ok thanks Tony
I thought so since it doesn't affect the model build it self
Ronald
This page was generated in 0.075 seconds.
