80 Pages «<4243444546>»
Sticky Wickett
#861 Posted : 11 April 2019 22:08:21
I then continued adding the rest of the supports around the perimeter of the lower deck. The attached photo shows the next two supports fixed in place.
Sticky Wickett
#862 Posted : 11 April 2019 22:11:08
The guard rail is split in two; upper and lower halves. I decided to build up the lower half first as this section will also have gauze attached.
The attached photo shows the 0.8mm diameter brass tube cut into 10mm lengths that will make up the vertical rails for the lower section.
Sticky Wickett
#863 Posted : 11 April 2019 22:11:50
Three of the vertical guard rails temporarily fitted.
Sticky Wickett
#864 Posted : 11 April 2019 22:16:21
To make up the horizontal rails i used Albion Alloys 'Connecto' which is bought in pack form and contains PE of different shapes. Each 'leg' of these shapes slides into the corresponding brass tube; in this case the 0.8mm diameter tube has an internal diameter of 0.6mm and the PE shapes have a width of 0.6mm. You can buy differing sizes that fit into the corresponding brass tube and all sorts of shapes can be made up using this clever product.
Sticky Wickett
#865 Posted : 11 April 2019 22:16:54
This photo shows one of the PE shapes.
Sticky Wickett
#866 Posted : 11 April 2019 22:19:48
By carefully bending the brass tube using brass rod slid inside to prevent crimping, i formed the correct curve and cut it into two lengths. I then attached theses two horizontal guard rails to the vertical ones.
#867 Posted : 11 April 2019 22:21:38
Lovely work as usual Phil.Love
Sticky Wickett
#868 Posted : 11 April 2019 22:22:05
From another angle.
I'm pretty pleased with the way it's gone so far, albeit fiddly, which is good as making the guard rails for the lower deck and upper deck will take awhile!Blushing Blink LOL
Sticky Wickett
#869 Posted : 11 April 2019 22:23:01
That's it for this week.
Thanks for looking in, have a great weekend and happy modelling!BigGrin
Phil W.
Sticky Wickett
#870 Posted : 11 April 2019 22:28:13
Thank you Mark!Cool BigGrin Making these guard rails will take awhile, so bear with!LOL Blink
Phil W.
#871 Posted : 12 April 2019 10:47:45
Stunning as always Phil, lots of great tips being shown on scratch building techniques.... Very well done....Love Love Love
Sticky Wickett
#872 Posted : 12 April 2019 11:46:19
Thank you Alan!Blushing BigGrin Cool Stay tuned for more guard rail adventures next week!
Phil W.
#873 Posted : 12 April 2019 23:20:36
Phil
That albion alloys connector set looks very useful.
Seen it on their site but this is the first i have seen with it being used. Gives a very neat finish to your guard rails.
But most of all impressed with your tube bending skills - must be taking some skill to get all those curves on the rails just how you want.
Hope it continues well.
Tony
#874 Posted : 13 April 2019 00:34:23
BigGrin All looking good Phil and nice workCool
Kev the Modeller
#875 Posted : 14 April 2019 10:58:49
Top job as always Phil, with more great scratchbuilding, well done. ThumpUp
Per Ardua Ad Astra
Garth
#876 Posted : 16 April 2019 12:09:52
Hi Phil,
Great update as usual!!!
Thanks as well for all the tips & techniques.
Kind regards,
Garth
"Measure twice, cut once!!!"
Finished!!! HMS Victory,
Current build: Black Pearl.
Wish list: USS Constitution.
#877 Posted : 16 April 2019 12:49:15
Cool looking good PhilBigGrin
DaDokta
#878 Posted : 17 April 2019 09:29:23
Another great update!
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
Sticky Wickett
#879 Posted : 17 April 2019 23:07:27
birdaj2 wrote:
Phil
Tony
Thank you Tony!BigGrin Regarding the tube bending, I make sure I have a small diameter brass rod that matches the internal diameter of the brass tube i'm bending to prevent crimping.
Phil W.
Sticky Wickett
#880 Posted : 17 April 2019 23:08:29
Thank you very much Andy!Cool
Phil W.
Guest (13)
This page was generated in 2.172 seconds.
