80 Pages «<4445464748>»
Sticky Wickett
#901 Posted : 25 April 2019 22:50:34
Just a short update this week due to the extended Easter weekend.
This week I finished off the lower guard rails on the port side of the lower deck of the conning tower and then concentrated on adding the protective mesh to the lower half of the starboard side guard rails.
Sticky Wickett
#902 Posted : 25 April 2019 22:54:33
I stripped a very thin piece of electrical wire of it's insulation and then unwound each strand so that I could use each of these strands to wrap around the vertical guard rail supports. By twisting them so that they pulled the mesh in tight to the vertical supports and thus required no glue.
Pretty fiddly work, but now I have a technique, I aim to complete the rest of the mesh by my next update.
Sticky Wickett
#903 Posted : 25 April 2019 22:55:53
Showing the mesh further along. I cut it as one long piece and trimmed it as necessary.
Sticky Wickett
#904 Posted : 25 April 2019 22:57:27
From above showing the mesh attached to the starboard side. At this point I have yet to trim the twisted wire strands that hold the mesh to the vertical guard rail supports.
Sticky Wickett
#905 Posted : 25 April 2019 23:00:52
Well that's it for this week. Just a short update due to the long weekend. As I mentioned before, now I have a technique for fixing the mesh, which did take time to figure out, I hope to make better progress next week and complete the rest of the safety mesh.Cool Blink
Thanks for looking in, have a great weekend and happy modelling!BigGrin
Phil W.
#906 Posted : 26 April 2019 07:35:46
Great work Phil. I’m convinced you miniaturise yourself when building this kit.LOL Love Love
Sticky Wickett
#907 Posted : 26 April 2019 09:11:43
HahahLOL You've sussed me out Mark!Flapper Thanks for looking in mate!Cool BigGrin
Phil W.
#908 Posted : 26 April 2019 09:31:48
Excellent idea for fitting the mesh Phil and I'm sure other modellers will adopt your method in some of their builds....Drool Drool .. All looks superb and look forward to your next session.....Cool Cool
DaDokta
#909 Posted : 26 April 2019 12:16:31
Great idea, excellent update!
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
Sticky Wickett
#910 Posted : 26 April 2019 13:10:44
Thank you Alan. You had me down as Walter, so changed your quote when replying!Flapper
By twisting the wire strands over and over, they really pull the mesh in tight to the vertical guard rail supports. Not too tigh though, as the wire will eventually snap, as i found out when trying out this technique.
Phil W.
Sticky Wickett
#911 Posted : 26 April 2019 13:11:31
Thank you very much Walter!!Cool BigGrin
Phil W.
#912 Posted : 26 April 2019 13:52:59
Phil W.
Oops....Blushing Blushing Blushing Blushing … Its an age thing....Laugh Laugh .. Have edited to put to right...Cool Cool
Kev the Modeller
#913 Posted : 28 April 2019 12:27:28
Another excellent update Phil and some nice work on those railings and mesh. Glad that you found a method that works for the mesh attachment, always a very satisfying feeling when you overcome a problem in modelmaking.
Well done! Cool ThumpUp
Per Ardua Ad Astra
#914 Posted : 28 April 2019 17:43:07
BigGrin All looking good Phil and nice workCool
Sticky Wickett
#915 Posted : 02 May 2019 07:13:48
Thank you Kev! Yes, i'm happy with the look and also the method now and you're right, it is satisfying when you hit upon a solution.
Phil W.
Sticky Wickett
#916 Posted : 02 May 2019 07:15:31
Thank you very much Andy. Appreciated!
Phil W.
Sticky Wickett
#917 Posted : 02 May 2019 07:20:10
Good morning from 'The Dockyard'.
Another quick update this week as I have a long weekend booked and i'm off camping! Could do with being a tad warmer, but there you go! lolLOL
Anyway, I managed to finish the rest of the mesh on the bottom half of the lower deck guard rails.
Sticky Wickett
#918 Posted : 02 May 2019 07:21:32
All the wire strands have been trimmed and their ends folded in.
Sticky Wickett
#919 Posted : 02 May 2019 07:22:34
Port side.
Sticky Wickett
#920 Posted : 02 May 2019 07:23:22
From another angle.
Guest (26)
This page was generated in 4.598 seconds.
