Template Options
Ant62
#1 Posted : 27 April 2019 09:24:53
Seeing that there isnt an diagram with the template copy how do you progress to build the gallery!
I have looked at the online instructions and there isnt anything with regards to making one..
So how do you proceed.....
Building.
HMS Victory.....
Corel Albatross 1840......Completed
Hindenberg Zepplin museum piece..Completed
Artesian Latina Sopwith Camel.....Completed
Bismark.........
#2 Posted : 27 April 2019 09:35:58
Build stage 24 shows the template on a 1:1 scale. You need to accurately trace the template onto some stiff card as outlined in post #6 here... Cool Cool
https://forum.model-spac...aspx?g=posts&t=1095
Ant62
#3 Posted : 27 April 2019 10:11:48
If the template is a jpeg they will not open.....
Building.
HMS Victory.....
Bismark.........
#4 Posted : 27 April 2019 10:19:16
If you are working from the PDF instructions then you will need to print off the template page on 1:1 scale (page 98 of this link) in order for you to be able trace onto some stiff card.
https://www.model-space....e/download/file_id/422/
Ant62
#5 Posted : 27 April 2019 10:28:24
Cheers.
So if i print to A4 size it will be correct.....
Building.
HMS Victory.....
Bismark.........
#6 Posted : 27 April 2019 11:00:35
Hi Ant, have sent you a PM....
Ant62
#7 Posted : 27 April 2019 12:32:12
BigGrin ta.........
Building.
HMS Victory.....
Bismark.........
This page was generated in 0.191 seconds.
