2 Pages 12>
Gatling Gun 1874 Options
Mustang
#1 Posted : 06 May 2019 11:07:25
So while I wait for the oils on the Mossie to dry, I thought Id do something small a quick.
But instead of going though my ever growing stash, I found this on eBay for £18 inc p&p great price as Ive seen them going for £50+
1/32 scale Gatling Gun by Verlinden.
To build:-
Mustang
#2 Posted : 06 May 2019 11:08:28
Parts list
To build:-
Mustang
#3 Posted : 06 May 2019 11:09:40
The instructions
To build:-
Mustang
#4 Posted : 06 May 2019 11:11:38
The parts, as this was second had there was a piece missing number 12 Gun barrel elevator
To build:-
Mustang
#5 Posted : 06 May 2019 11:14:11
First up I need to remove the axle as it was fitted the wrong way round.
So I managed to prise them apart with out damage.
Then cleaned and refitted the correct way round.
To build:-
Mustang
#6 Posted : 06 May 2019 11:16:03
Stage one finished
The underside view
And the top view, I also redone the grab handles.
To build:-
Mustang
#7 Posted : 06 May 2019 11:19:30
Next I need to make a new Gun elevator pin, I could have just added a piece of brass rod.
But I decided to add the screw detail to it.
I also left a small piece of rod at the end where it will meet the barrel housing.
To build:-
Mustang
#8 Posted : 06 May 2019 11:20:31
Look about right.
To build:-
Mustang
#9 Posted : 06 May 2019 11:22:18
The rear of the barrel chamber was missing a small detail, so I added a small piece of plastic.
To build:-
Mustang
#10 Posted : 06 May 2019 11:24:25
Managed to break this piece .
But managed to repair it by adding a piece of plasticard which you can just see in the above photo
To build:-
Mustang
#11 Posted : 06 May 2019 11:28:44
This is what is supplied to build the barrels.
Instead Ive used brass rods.
Added the centre one to get the front end fitted
Then added two more for support.
The others will be added once its all painted.
To build:-
Mustang
#12 Posted : 06 May 2019 11:29:35
Dry run.
To build:-
Mustang
#13 Posted : 06 May 2019 11:33:31
Final part of the build is the wheels, this is the jig to build them. Took me awhile to remove all the crap around the outside just so I could get the rims to fit.
Hubs and spokes.
Fitting the parts.
There was small holes in the rims for where the spokes went, I gentle drilled these a bit bigger so the spokes would fit in them.
To build:-
Mustang
#14 Posted : 06 May 2019 11:35:23
The finished wheel view from the rear.
The front view.
Dry fit.
To build:-
Mustang
#15 Posted : 06 May 2019 11:38:11
More once I've started the painting.
To build:-
#16 Posted : 06 May 2019 11:46:09
Looks and excellent little kit and a great job you're doing with it too....Cool Cool .. Will look fab when all painted up.....Cool Cool
Kev the Modeller
#17 Posted : 06 May 2019 12:05:12
Looks a fabulous little kit Ian and at a great price too, even with the odd missing part. Excellent work so far, love those wheels and some nice scratchbuilding from you too with the screw fitting and barrels.
Very well done, will be watching and commenting on this build along the way. Cool ThumpUp
Per Ardua Ad Astra
#18 Posted : 06 May 2019 12:07:37
Isn
You got yourself a bargain there. As you say some of the rare verlinden items are fetching a hefty price tag. Bern picking up some bits and pieces in their "North and South" civil war range but proably 9 out of 10 "i would like" end up way out of my price bracket.
That wheel jig they supplied in the kit is a neat idea to give a good finish to the wheel spoke layout.
Looks like its all coming together very well and hope it contiunes in the same way for you.
Tony
CaptnBirdseye
#19 Posted : 06 May 2019 17:33:26
Rank: Superelite
BigGrin Now this is something different......and extremely interesting! Well done, great find you’ve got there Mustang. Can’t wait to see what you do with her ThumpUp
Regards Gray
Mustang
#20 Posted : 06 May 2019 18:41:18
So had a go at the wheels, base coat and and then sealed.
The left one is the base coat and the right is the one stained up.
To build:-
Guest (10)
2 Pages 12>
This page was generated in 0.415 seconds.
