 Rank: Pro Groups: Registered
Joined: 29/12/2018 Posts: 223 Points: 671 Location: Lancashire
I decided to take the girl downstairs into the kitchen to do a bit on the next lot of canon ports that was a non starter. Scapel still up stairs so went to get it. The 12mm x 12mm template again upstairs so off i trudged.... Started the 3 canon ports half wya through the first one ping blade snapped and guess where the blades where! Yes upstairs.... So i ended up taking the girl back up..... Ant62 attached the following image(s): Building. HMS Victory..... Corel Albatross 1840......Completed Hindenberg Zepplin museum piece..Completed Artesian Latina Sopwith Camel.....Completed Bismark.........
Hi Ant62, looking good you must be very pleased with your work, those ports are a bit trick at best,with my build i drilled around the shape and then used a small file to finish off. trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Looking good..... Regards Alan
tf64 wrote:Hi Ant62, looking good you must be very pleased with your work, those ports are a bit trick at best,with my build i drilled around the shape and then used a small file to finish off.
trev. Surprisingly quite quick using the scapel and you get to know its uses.... Building. HMS Victory..... Corel Albatross 1840......Completed Hindenberg Zepplin museum piece..Completed Artesian Latina Sopwith Camel.....Completed Bismark.........
I have almost completed the 3rd level of canon ports and according to the official videos i should have painted cut the 20mm and 15mm blocks.. Now these length of wood are not in the packets stage as or as in the videos or the pdf.... So do i cut them and place them to cover the upper deck canon port as in the picture.. Ant62 attached the following image(s): Building. HMS Victory..... Corel Albatross 1840......Completed Hindenberg Zepplin museum piece..Completed Artesian Latina Sopwith Camel.....Completed Bismark.........
Yes, they serve two purposes.
Firstly they need to be drilled to take the dummy cannon so they need to go above half way. Secondly, the whole area needs to be painted black in order not to let light though.
These should have been in place before laying the middle deck.
Well following the video and the PDF say when to place these pieces of wood but infact they arrived in a later box so i couldnt paint cut place them... But never mind it will do it later after the canon ports are cut.. Building. HMS Victory..... Corel Albatross 1840......Completed Hindenberg Zepplin museum piece..Completed Artesian Latina Sopwith Camel.....Completed Bismark.........
I went off track a few times during the build for a reason but you need to be absolutely clear what you are doing and why. Generally though, it is best to follow the build process to the letter, even if it might mean waiting, to ensure that you can do what you have to do at a later time.
z8000783 wrote:I went off track a few times during the build for a reason but you need to be absolutely clear what you are doing and why. Generally though, it is best to follow the build process to the letter, even if it might mean waiting, to ensure that you can do what you have to do at a later time.
Quite easy done to go off course... So justvto clarify the cut blocks are to be placed behind the upper deck canon port make it look like the lower decks.... Building. HMS Victory..... Corel Albatross 1840......Completed Hindenberg Zepplin museum piece..Completed Artesian Latina Sopwith Camel.....Completed Bismark.........
No, I took a different route on occasion but I did a lot of research to make sure I didn't create any problems for the future. As I say though, at the detailed level, it's important to follow the instructions fully.
Right im lost now..... The black cut 15mm or 20mm block goes A next to the canon port or B behind the canon port... Ant62 attached the following image(s): Building. HMS Victory..... Corel Albatross 1840......Completed Hindenberg Zepplin museum piece..Completed Artesian Latina Sopwith Camel.....Completed Bismark.........
I have now sussed it after watching the video again again again very carefully.... Building. HMS Victory..... Corel Albatross 1840......Completed Hindenberg Zepplin museum piece..Completed Artesian Latina Sopwith Camel.....Completed Bismark.........
It goes behind the port in order to take the dummy cannon. You will need to drill into it right in the centre of the gun port.
Making good progress Ant, well done.... Regards Alan
Ive taken a short break away from the build for a while etc A fresh look at the build later.....  just realised i have missed several canon ports have to do them and then leave the build for a bit.... Building. HMS Victory..... Corel Albatross 1840......Completed Hindenberg Zepplin museum piece..Completed Artesian Latina Sopwith Camel.....Completed Bismark.........
Well finished the canon ports on both sides.... Have a break from it now need to be freshened up to do the hull.... Ant62 attached the following image(s): Building. HMS Victory..... Corel Albatross 1840......Completed Hindenberg Zepplin museum piece..Completed Artesian Latina Sopwith Camel.....Completed Bismark.........
Very nice progress, looking good. Mark Regards Markwarren (Mark) Admin
Very neat work. That is a whole load of cut outs you have to do but well done for getting to the end of them. Tony Happy Modelling
birdaj2 wrote:Very neat work.
Tony Thanks for that... Building. HMS Victory..... Corel Albatross 1840......Completed Hindenberg Zepplin museum piece..Completed Artesian Latina Sopwith Camel.....Completed Bismark.........
Well here is the lady hull side up.... Ant62 attached the following image(s): Building. HMS Victory..... Corel Albatross 1840......Completed Hindenberg Zepplin museum piece..Completed Artesian Latina Sopwith Camel.....Completed Bismark.........
Guest (13)
