 Rear lights done and the reg plates fitted which just about finishes the Cosmo next its the XR-8. arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Another stunning production from the ARPurchase factory.... beautifully done Andy.... Regards Alan
Joined: 22/03/2016 Posts: 175 Points: 552 Location: Merseyside
Another fantastic build and a nice choice of cars too, the wankel engine never gets the credit it deserves Steve Built- Shelby Mustang, Lamborghini Huracan Building-Spitfire, Redbull racing RB7, 3d printer, Honda CB750, Stage coach and Revell 1/400 Titanic
 Thanks for looking in and your comments everyone, the sad end for the Wankel engine came when they couldn't get the imisions down low enough in Europe and the USA . Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Moving on with the RX-8 clean up done and the undercoats on. arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 The colour is starting to go on now semi gloss black for the underframe and cockpit, Mazda Velocity Red by Zero paints on the main body and bumpers. arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 RX-8 is finished two down 1 to go arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Thanks for looking in and your comments kev.There wasnt much to do or many parts for the second kit so it went together very quickly Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Thanks for looking in and your comments Roger Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,866 Points: 17,750 Location: ipswich
A great result there Andy. A lovely finish on that paint.
Roy.
 Thanks for looking in and your comments Roy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,413 Points: 22,549 Location: Northamptonshire, England
Very nice work Andy, love the paint job you’ve done on them. Mark Regards Markwarren (Mark) Admin
 Thanks for looking in and your comments Mark Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Truly love the finish you've achieved on the body, a true work of art..... Regards Alan
 Thanks for looking in and your comments Alan Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Third kit started, I have just discovered that Tamiya are to do a re-release of the Mazda 787B kit so I will be saving the after market stuff I had for that kit when I get it. The upper bodywork had a few bits added and then undercoated along with the dash, cockpit parts and floorpan. All the cockpit parts were then sprayed semi gloss black along with the floorpan and the inside of the upper body. Next its a tack of the upper body to the floor pan some masking and the Zero paints base white to be sprayed on the upper body befor more masking and the green and orange sprayed on. arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 The white base coat is on now, it needs to cure for 24 hours before more masking goes on. arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
