Colour change Options
#1 Posted : 20 May 2019 18:15:56
While my jag build has only just moved onto the rear suspension, so a while away from getting any major body parts, i was wondering if a re-spray would be easy or not.
I am not 100% happy that the bonnet and doors really have the depth of colour and shine i see in the model in the launch advert.
Recently i saw on facebook someone had re-sprayed theirs in a similar but metallic green. Really lovely deep shine and smooth finish to the paint.
I know you would have to rub down the existing paint and prime but just wondering if anyone has any views with this being a diecast model (ie if i rub off the existing paint am i going to end up with a bad surface possibly).
I guess with the interior colors it maybe limits the body colours but any suggestions or advice would be most welcome.
Thanks
Tony
#2 Posted : 20 May 2019 18:45:33
I know I'm going to do a roadster version but I'm also going to change the body colour to primrose yellow, and the interior to dark red.
I'll rub down the exterior green paint with wet and dry, prime with Halfords grey, then Halfords white, then a few coats of yellow...
Jump in - have a bash. It's all good fun.
#3 Posted : 20 May 2019 19:23:06
Roy
Thanks for the advice. Sounds like a plan.
I have used halfords primers in the past on plastic kits so i know they are some decent primers.
I think i will give it ago (it was always at the back of my mind) as it certainly needs a better finish (certainly on mine).
Just need to track down a suitable top coat then. Those zero paints look quite useful unless halfords have something in a can that would make the task easier.
Thanks again
Tony
This page was generated in 0.246 seconds.
