screw drive will pick up screws any more lost it's magnetisem Options
ronald305
#1 Posted : 21 May 2019 20:21:39
Hello there
would anyone know how to re-magnetize the screw driver it will not pick any screws any more thank you
Ronald
#2 Posted : 21 May 2019 20:37:25
Get a few rare-earth magnets (cheap on Ebay) and just stick them to the side of the screwdriver blade.
Done.
Roy.
#3 Posted : 21 May 2019 21:13:25
Good suggestion from Roy you already have but another option might be a screwdriver magnetiser.
These allow you to magnestise the scredriver blade and also to de-magnetise should you want.
Have a search on ebay using "screwdriver magnetiser" as your search.
Here in the UK i could order one for 99pence which is approx $1.26 and that includes postage.
Tony
andali15
#4 Posted : 21 May 2019 21:20:02
Both good suggestions. I use an old magnet from the back of a stereo speaker, just slide blade across magnet, all done. Andy.
ronald305
#5 Posted : 21 May 2019 21:37:56
Thanks everyone for your ideas😊
Ronald
R2D2Nut
#6 Posted : 28 May 2019 19:11:43
You don't have to have any special magnets. Just find one that will make your screw driver stick to it and just rub the screw driver tip on the magnet. Basic science/magnetism.
Fred
R2D2Nut
#7 Posted : 13 August 2019 10:39:51
Oh yeah, something else. If you just don't have ANY magnets around, then do you have a few inches of insulated small gauge wire and a 9v battery? Wrap a few turns of wire around your screw driver and connect the battery to the terminals of the battery for a couple of seconds and it should now be magnetized if you did everything right. All you are doing is making a small electromagnet.
Fred
This page was generated in 0.102 seconds.
