 Rank: Pro Groups: Registered
Joined: 08/02/2015 Posts: 426 Points: 1,259 Location: Louisiana
Hello there would anyone know how to re-magnetize the screw driver it will not pick any screws any more thank you Ronald
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,736 Points: 17,360 Location: ipswich
Get a few rare-earth magnets (cheap on Ebay) and just stick them to the side of the screwdriver blade.
Done.
Roy.
Good suggestion from Roy you already have but another option might be a screwdriver magnetiser. These allow you to magnestise the scredriver blade and also to de-magnetise should you want. Have a search on ebay using "screwdriver magnetiser" as your search. Here in the UK i could order one for 99pence which is approx $1.26 and that includes postage. Tony Happy Modelling
Both good suggestions. I use an old magnet from the back of a stereo speaker, just slide blade across magnet, all done. Andy.
Thanks everyone for your ideas😊 Ronald
Joined: 28/12/2018 Posts: 67 Points: 213 Location: United States
You don't have to have any special magnets. Just find one that will make your screw driver stick to it and just rub the screw driver tip on the magnet. Basic science/magnetism. Fred
Oh yeah, something else. If you just don't have ANY magnets around, then do you have a few inches of insulated small gauge wire and a 9v battery? Wrap a few turns of wire around your screw driver and connect the battery to the terminals of the battery for a couple of seconds and it should now be magnetized if you did everything right. All you are doing is making a small electromagnet. R2D2Nut wrote:You don't have to have any special magnets. Just find one that will make your screw driver stick to it and just rub the screw driver tip on the magnet. Basic science/magnetism. Fred
