Making rigging more realistic. Options
goddo
#1 Posted : 23 May 2019 16:32:15
Afternoon all,
As the title above says, how do I make some of the "loose" rigging look more realistic?
I am building a model (1:64th Amati Revenge) without sails and some of the rigging is "loose" or "hanging loose".
I can't think of a better way of describing this but the thread will not hang in a smooth curve even
though I have added some weight to it by drawing it over a bees wax block a good few times.
Admittedly, the thread is only 0.75 thick but I had hoped for a better result.
Your experience and know how would be appreciated. Thanks.
#2 Posted : 23 May 2019 17:19:15
The only piece of rope work I’ve done is more recently with the LVCP D-day diorama. I wanted the rope to look realistic and hang right. I dabbed the rope useing super glue to shape it where it needed to be. I would practice first and don’t superglue your fingered. LOL
nightwisher
#3 Posted : 23 May 2019 17:28:19
I have used watered down p.v.a on foot ropes to make them sag ,might be worth a try
Had a dream to understand
A single grain of sand
He gave birth to poetry
But one day will cease to be
#4 Posted : 23 May 2019 17:48:51
Hi Goddo!
This is purely theoretical as I haven't actually tried it myself, only thought about it! Blink
You could try a type of 'false rigging' by using nightwisher's method with the pva glue but with the following:
Find a solid object to make a former with a curve similar to the 'sag' you want to achieve, something like a saucepan or similar and wrap a layer of cling film around it. Then soak the thread in the pva solution and lay it around the wrapped former (several times if you need a lot) and allow to dry and stiffen up. Then lift the pre-shaped dried thread off the former and cut a length to match your rigging. If it was coming from a rigging block for example you'd need to leave the hole in the block free (or re-drill it out) and then super glue the end of the thread in before fixing the other end wherever that goes to. This method would need a bit more planning ahead to determine where it starts and where it ends but should provide a subtle curve which won't alter after time. Like I said - theoretically!BigGrin
Best of luck!
Robin.
goddo
#5 Posted : 23 May 2019 18:14:35
Thanks for the advice guys.
Markwarren: Not too sure about the superglue option as this makes the rigging very rigid and, in my eyes, a bit unrealistic.
Plymouth57: I like the sound of your suggestion with watered down PVA formed around something of the suitable radius.
All I need to do now, is persuade my wife that her saucepans are allowed to be used in such a scheme......NO chance!
I’ll let you know how I’m progressing as soon as possible.
#6 Posted : 23 May 2019 22:05:11
Errr, I know! DON'T TELL HER! LOL LOL Flapper
nightwisher
#7 Posted : 24 May 2019 05:23:29
She will know ,They always know Sad
Sparky1962
#8 Posted : 24 May 2019 07:34:27
morning goddo & nightwisher
have a suggestion get your own saucepan(s). get them from a charity shop, win-win. if your better halves moan tentatively suggest using hers!!! just a thought.
goddo
#9 Posted : 24 May 2019 08:57:49
Why do I get the impression that this post is generating a can of worms?
You guys must be much braver than I am to even consider pinching saucepans.
Anyway, I tried the idea of watered down PVA last night and just laying it on the bench to get the curvature on a test piece of rigging and while it worked to an extent, the rigging that I am working on is black thread so the glue makes it look a bit grey.
Perhaps a weaker solution will do a better job.
I will persist (like Mrs May) and come back to you with a solution (unlike Mrs May)
#10 Posted : 24 May 2019 10:05:54
BigGrin Hi goddo. I have had the same problem with PVA on black thread but came up with a solution. What I did was to water down the PVA with watered down black acrylic paint, leave to dry and bingo nice stuff or curved black thread
Hope this helps
Martyn
goddo
#11 Posted : 24 May 2019 10:36:40
Hope this helps
Martyn
Brilliant idea Martyn,
Thanks very much for the solution to the problem.
That's what I love about this forum. There are always knowledgeable and helpful people who respond.
Onwards and upwards.
Goddo
#12 Posted : 24 May 2019 11:10:53
BigGrin No problem m8 always happy to help Cool
Martyn
Guest (6)
This page was generated in 0.178 seconds.
