Stage 31: Completing the upper planking Options
gidaban
#1 Posted : 25 May 2019 13:48:21
Rank: Member
Hello guys, i have question about it
in instruction is 19 mm what it if i have more then 20? i should flush it?
#2 Posted : 25 May 2019 14:25:29
Have a look here at Stage 31 of the Official Build, it explains about adjusting the bulwark heights....
https://forum.model-spac...aspx?g=posts&t=1573
At this stage of the build the 19mm height you are quoting is the minimum height you need to have, heights will all be adjusted later in the build....
Hope this helps
gidaban
#3 Posted : 25 May 2019 14:41:24
Rank: Member
i found it
"Now measure the height of the bulwarks at frame 22, it should be at least 19mm above the top deck support bracket, use the same process to raise the height of the bulwark if necessary."
but nothing about if is more like 20 mm. Then leave it for now, and continue ?
#4 Posted : 26 May 2019 09:06:37
gidaban wrote:
i found it
Yes, leave it for now as advised in the Official build here:
Adjusting the height of the Bulwarks
Check the height of the completed planking around the forecastle and quarter deck, if necessary you may need to add extra strips to ensure that the planking finishes at the correct level, (don't worry if any bulwarks are higher than quoted, they are sanded to the exact size later, after the internal planking is added).
This page was generated in 0.038 seconds.
