INFINI Masking Tape Cutting Boards Options
#1 Posted : 25 May 2019 18:02:20
INFINI MASKING TAPE CUTTING TEMPLATES
As your modelling develops there are a lot more tools available that can be added to your kit box.
While there are a range of ESSENTIAL tools you need there will be some that can be considered more of a “luxury” but these will prove of use over the years (if you look after them).
These boards are a case in point.
What we have here are a selection of 4 boards each of which have etched lines moulded in.
These allow you to put stock lengths of masking tape/masking sheets on the board and then using the point of a sharp blade to trace the etched lines, cut some “weird and wonderful” shapes for just about all of the masking tasks you could ever imagine.
Each of the boards are 210mm x 115mm and are rigid at around 6mm thick.
What is interesting if you look at my pictures is that 2 earlier ones I purchased were issued under the “AK – INTERACTIVE” brand with the other 2 being under the manufacturers name “INFINI”.
It’s a bit like the DSPIAE range of tools which you will see are also available under the MENG brand.
I have attached a selection of pictures but if you want to look in more detail here is a link to the INFINI website:
http://infini-model.com/...0product/tool-material/
In the UK you can get these via Sovereign Hobbies and sometimes some better deals in terms of price can be found on eBay.
This page was generated in 0.281 seconds.
