Andali15. Samba build Options
andali15
#1 Posted : 31 May 2019 19:35:24
Hi all, decided to try and put up my build of the Samba. Not the full detailed build but what I have so far. I didn’t like the battery that came with the build so got a proper battery from Roy ( roymattblack ) and I think it’s far superior to original item supplied with kit. Highly recommend it. Hope the pictures come out ok. Andy. 04.04 added 8 more photos of finished build. Andy.
andali15
#2 Posted : 04 April 2020 12:00:49
Have added 8 photos of finished build. Replaced sunroof, added seatbelts from scratch, had wheel rims painted c/o Roymattblack and included a fire extinguisher. Andy.
#3 Posted : 04 April 2020 12:55:27
Great that you are posting your build but ideally the images should be smaller than 145kb.
That way, they will show on the page.
As they are currently, each one needs to be downloaded which the majority of visitors won't do.BigGrin
andali15
#4 Posted : 04 April 2020 14:12:09
They come from my iPad Roy so that’s the size they are. Not being technical, old shillings and pence guy, how do I resize them .Andy.
#5 Posted : 04 April 2020 21:43:12
Hi Andy BigGrin
If you follow the link below you should find the info you need to adjust your pics.
https://forum.model-spac....aspx?g=posts&t=244
If you still have problems then come back and will try and help. I don`t have an ipad but it shouldn`t be much different. Blink
This page was generated in 0.155 seconds.
