13 Pages <1234>»
Micks 1/200 battleship bismarck Options
#21 Posted : 04 May 2019 14:29:13
Issue 10
Here we get second part of the deck, attach various details to it and fix it to the bow deck. Cheers mick.
#22 Posted : 04 May 2019 19:17:26
BigGrin Looking good Mick and going together wellCool
Kev the Modeller
#23 Posted : 04 May 2019 20:21:23
Nice work Mick, looking great and making nice progress with this, well done. ThumpUp
Per Ardua Ad Astra
Sticky Wickett
#24 Posted : 07 May 2019 16:27:02
Nice start there Mick!
Phil W.
#25 Posted : 01 June 2019 16:20:01
Hi onto issue 11, here we get the hull plates to get both sides of the hull the same, and 2 bits of stand.ill only use these in building, as will put it on brass pedestals at the end.cheers mick
#26 Posted : 01 June 2019 16:28:57
Issue 12
Here we attach the first main gun to the deck,with its various gears,the blast bags are not included in the kit,just something I added by cutting the fingers off of latex gloves and gluing to inside of turret,need to be this way as they need to work.cheers mick BigGrin
#27 Posted : 01 June 2019 16:43:12
Issue 13
Here we get another plate for Hull,but it's not used yet,then support brackets for the barrel elevation gearbox, this is just then attached underneath to secure the gearbox in place. Then we get the first 10 hinged breakwater supports, I found it easier to fit the metal hinges in first then cut them off sprue, then glue them in place, I'll paint them when get the other 10.cheers mick.BigGrin
#28 Posted : 01 June 2019 16:47:37
Issue 14
Quickey this one just attach the turret rotation motor in place. That me caught up now catch you again when get me next parts cheers mick.BigGrin
#29 Posted : 01 June 2019 20:24:04
BigGrin All looking good Mick and nice workCool
#30 Posted : 02 June 2019 08:13:44
Good steady progress Mick, all looks good.....Cool Cool
#31 Posted : 02 June 2019 17:59:52
Looks good Mick.
Mine has not even got off the ground as yet.
Had 4-6 back on 12/04 and nothing since.
They tell me they are out of stock of issue 10 so hold up all 4 editions on that basis.
In 2 minds about carrying on to be honest because 140 issues with delays already at issue 10 is concerning.
Ifyou are interested in what is still to come the German site has the parts and instructions listed (up to issue 26 at the moment)
https://bismarck-bauen.de/vorschau/
Hope yours continues well.
Tony
#32 Posted : 02 June 2019 22:27:34
Hi it's a shame if you discontinue, but it's not good this early I agree ,my jag bin on hold for 4 months cause out of stock issues,cheers mick.
#33 Posted : 29 June 2019 14:32:35
Issue 15
Here we get another plate for the hull, simply screw it to the previous plate supplied, then it's put in the other 10 breakwater hinges, cheers mick.BigGrin
#34 Posted : 29 June 2019 14:35:20
Issue 16
Nice simple one this just attach the barrel elevation motor, to the main gun.cheers mick. BigGrin
#35 Posted : 29 June 2019 14:38:53
Issue 17
Another simple one just attach the circuit board box,to anchor gearbox, and plug in all the connections from the various motors. Cheers mick. BigGrin
#36 Posted : 29 June 2019 14:47:42
Issue 18
Here basically we test the functions of the main turret and the anchors with the supplied tester box, when you first switch on the gun will rotate to its limit one way, pause for few seconds then return to center and stop, then press s1 button the gun will rotate the other way firing and elevating all at same time,these functions will be separate when get the final remote, then press s2 and the anchors will raise and lower in small steps, mine all works very smoothly, well that's it till next parts arrive,cheers mick.BigGrin
CaptnBirdseye
#37 Posted : 29 June 2019 14:49:44
Rank: Superelite
BigGrin Good work, as usual Mick ThumpUp
#38 Posted : 29 June 2019 23:40:53
She's looking good Mick, going to be a big lady when finished....Cool Cool
#39 Posted : 29 June 2019 23:44:29
Hi Mick, has this been resolved? If not, can you PM me with the details and include your subscription number....
#40 Posted : 25 July 2019 18:10:25
Hi thanks to all who looked in and left comments much appreciated.
Issue 19
Here we get another piece of deck which we attach the second gun barbette to.then it's assemble the bow jackstaff, and test the light at the front all easy enough to do. Cheers mick BigGrin
Guest (23)
13 Pages <1234>»
This page was generated in 0.379 seconds.
