Scale Options
gary2sail
#1 Posted : 04 June 2019 15:34:34
Rank: Beginner Level 1
What is 1:84 scale is measurements? e.g. 1cm to 84cm or is 10mm to 84m.
because try work out measurements from a plan to the model.
#2 Posted : 04 June 2019 16:55:56
This might help you. But is it 1:84 you are working with as that is not a common model scale.
Its an online scale conversions site.
You can input the required scale snd then get it to convert from real to scale or from scale to real
https://www.ginifab.com/...ch/scale_converter.html
For instance 1cm using 1:84 scale gives you 84 cms
Tony
This page was generated in 0.031 seconds.
