R2D2 won’t power up Options
Debra
#1 Posted : 19 June 2019 22:37:43
Rank: Beginner Level 1
I didn’t let the batteries charge fully. It worked fine, but I took the batteries out to charge them fully and now nothing works. Is there a way to reset the whole thing. I bought this to build with my grandson. Lots of time and money latter nothing is working.
Steve1701
#2 Posted : 19 June 2019 22:44:12
you will have to reset, put the batteries back in, then put the power adaptor in and switch the power on for about ten seconds, then remove the adaptor, hopefully now the batteries will be recognised by the unit.
Debra
#3 Posted : 19 June 2019 22:47:12
Still nothing
Steve1701
#4 Posted : 19 June 2019 22:54:42
have you checked the voltage of the batteries, are they the same.
Debra
#5 Posted : 19 June 2019 22:57:00
No I am not that clever, it will have to wait til this weekend, and maybe my grandson can check that, I have no idea what to do. I know the batteries are all brand new and purchased together.
Steve1701
#6 Posted : 19 June 2019 22:58:23
you had a voltage checker with the build debra.
Debra
#7 Posted : 19 June 2019 23:02:50
I know I sound dumb, if that is the thing used to charge them, yes they were all the same. I think this was an expensive mistake. Should have left it alone.
Steve1701
#8 Posted : 19 June 2019 23:05:58
yes debra, it had a led display, and you are not dumb, there are no dumb questions, its just finding the fault.
Debra
#9 Posted : 19 June 2019 23:07:35
Thanks, but I will have to walk away for awhile. Frustrated.
Steve1701
#10 Posted : 19 June 2019 23:08:27
no problem, good luck, hope you get it sorted.
Moderator
#11 Posted : 20 June 2019 05:22:37
Groups: Forum Support USA, Moderator
Hi Debra,
The first thing is that as Steve mentioned, there are no dumb questions. (Actually, the only dumb question is one you DON’T ask!)
Are you using the single battery charger that came with the build? It’s critical that you do. Also, which batteries do you have? (Probably not the source of the issue, since it ran before)
Check the connection with the battery box. It’s possible you may have dislodged a connector. I know I don’t have a lot of cable to pull out when I’m accessing the battery box on mine.
That’s what jumps to mind right off...
Debra
#12 Posted : 20 June 2019 08:35:54
I am going to try this weekend to get to the connections and see if that’s the issue. The batteries are EBL
Debra
#13 Posted : 20 June 2019 20:15:18
He is back and functional, thanks all for the patience and advice, must have pinched a wire. Now to figure out voice control.
Steve1701
#14 Posted : 20 June 2019 21:14:45
thats good news debra, and well done.
Moderator
#15 Posted : 21 June 2019 04:27:49
excellent!!!
tschwand
#16 Posted : 22 June 2019 04:37:33
Debra Glad you got him working. Waiting with great trepidation for next month when my last shipment arrives. From what I've read on these forums, don't be too surprised if the voice control doesn't work. Seems like the microphone either doesn't work well or picks up so much noise that he can't "hear" you properly.
Debra
#17 Posted : 22 June 2019 11:06:37
I have not been very successful at getting voice control to work, which is disappointing. But still patting myself on the back for even attempting to build him.
This page was generated in 0.838 seconds.
