Well done Mark, excellent work on the repair.... Regards Alan
 Rank: Pro  Groups: Registered
Joined: 23/12/2018 Posts: 318 Points: 949 Location: Illinois, USA
So half way through construction of pack 5, I broke my second rivet tool (Trumpeter). Found a tool made by RP productions that I hope holds up for the remainder of the build. It cost as much as 3 trumpeter tools so hope it was worth the investment. We shall see... Mark mwstratton attached the following image(s): Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
Nice work on the repair Mark, fingers crossed for the tool. Mark Regards Markwarren (Mark) Admin
Those rivet markers get a real lot of use on this kit. Think I went through 3 of the Trumpeter ones and the fourth was near the end of its life. Hope the new one has more life in it. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Pack 5 This issue deals with the kitchen section. Mark mwstratton attached the following image(s): Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
Looking very neat Mark. Mark Regards Markwarren (Mark) Admin
Very nice Mark, great to see you moving forward again with this... doing a great job.... Regards Alan
Pack 6 I started off on pack 6 by getting the seat parts ready. Mark mwstratton attached the following image(s): Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
Pack 6 I've got the seat frames built and painted. Ready for assembly. Mark mwstratton attached the following image(s): Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
Nicely done Mark and making great progress with your build, well done, looking good.
Kev  Per Ardua Ad Astra
Pack 6 The seats are assembled and ready to fit to the floor. Mark mwstratton attached the following image(s): Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
Nice work Mark on those seats Bet your glad you are not building a Jumbo jet. Mark Regards Markwarren (Mark) Admin
Markwarren wrote:Nice work Mark on those seats Bet your glad you are not building a Jumbo jet. Mark LOL, they are quite time consuming. Mark Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
Very nice Mark, all looking good.... Regards Alan
Pack 6 I painted and flocked the passenger cabin floor and installed the seats. The molding around the bottom of the seat frames was made by scoring a long strip of aluminum sheet, masking it and painting the same color as the floor. I found that most of the paint peeled off while cutting and forming it around the seats. If I had it to do over, I would just score the line, cut and fit it then paint it once it was placed on the seats. Thanks for watching Mark mwstratton attached the following image(s): Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
That`s looking very good Mark. Quick question: Did you use a metal primer on the aluminium strips before applying the top coat? If not that could be why the paint peeled. Good luck moving forward. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
delboy271155 wrote:That`s looking very good Mark. Quick question: Did you use a metal primer on the aluminium strips before applying the top coat? If not that could be why the paint peeled. Good luck moving forward. Regards delboy271155 (Derek) Yes Derek, I used a thin coat of model masters white metal primer followed by 2 coats of Vallero Fire red paint. The stripe on about half of the strips peeled off like a decal. Mark Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
Looking excellent Mark. Mark Regards Markwarren (Mark) Admin
Pack 6 I've fitted the floor into the passenger cabin and glued the 2 sides of the fuselage together. Mark mwstratton attached the following image(s): Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
Mark Thats all coming together very nicely. Tony Happy Modelling
Guest (11)
