20 Pages «<7891011>»
Karl's H.M.V Endevour.Part work's with Eaglemoss. Options
#161 Posted : 04 August 2011 15:56:57
ISSUE28.just one layer of planks this week,(gonna take years at this rate)
so I did something different,I spliced the strake planks as in the real ship,(too much time on me 'ands.)although this will be covered up with the second layer,I felt I needed the practice.
#162 Posted : 04 August 2011 15:58:27
#163 Posted : 04 August 2011 16:02:45
#164 Posted : 04 August 2011 16:04:45
IAN
#165 Posted : 04 August 2011 16:05:16
Hi Karl..
The endeavour is looking good.
I have just recieved issue 28 will start the planking on my days off.
Best regards,
Ian
Ian
Wish list: Bentley Blower
#166 Posted : 04 August 2011 16:06:17
#167 Posted : 04 August 2011 16:59:19
Very nice KarlLove
#168 Posted : 11 August 2011 14:49:25
issue 29. wow loads to do this week.an anchor,not an ordinary anchor but a bow anchor.well here it is,all 10 pieces.
I had to use copper banding,the brass supplied was un usable,if you bend it,it breaks,so in the bin it goes.
#169 Posted : 11 August 2011 15:34:30
All terrific stuff Karl.....Brill anchor as well..keep the pictures coming mate..ThumpUp
Eddieboy
#170 Posted : 11 August 2011 15:50:11
All of your builds are top quailty Karl, I looked at this collection myself but was a bit put of by some of the early parts - wish I had done it now!!!!
Ed,
#171 Posted : 11 August 2011 19:37:23
thanks eddie and jonny,the early parts and some of the later parts are a -------bit suspect to say the least,but with a careful bit of work and replacements a decent model should emerge.the amount of building so far has been very low,had to find things extra to make it last,like treenailing the decks,splice joints for the planking with the pinning showing,although this will be covered up,I intend to splice the veneer as well.
#172 Posted : 11 August 2011 19:53:04
Hi Karl great job as usual mate. This build has a lot to be desired, given a choice 29 weeks ago I would not have got involved, but I have and Like you I will produce a ship I will be happy with.BigGrin
Silent_Running
#173 Posted : 11 August 2011 20:29:32
Tomick wrote:
Is she single or double planked?
It's double planked Mr T, I'm subscribed to this ship as well. In the DVD they send you, you do the basic planking, then cover with a second layer of finer wood. That's the plan anyway, although if the quality of the second layer is anything like the first??? Glare Cursing Well we will see.
I haven't started building mine yet, but judging by the comments from yourself Karl and MWG it looks like there might have to be a bit of kit bashing by the looks of it.
I don't know what you guys think about the quality of the parts? Blink
Didn't mean to hijack your thread Karl sorry mate! BigGrin
#174 Posted : 11 August 2011 20:46:13
silent no sweat,the quality is medium to poor,I have changed a few bits,but am determined not to spend extra on it,if I haven't got the replacement bits then I use what you get,but with an extra bit of spit and polish.
#175 Posted : 18 August 2011 19:39:47
well we are up to issue30.and we are really getting going,a whole 2 more layers,wow eee,I thought deag were stretching out issues but this is ridiculous.because of the slow progress I will include my method on this model of how I am planking it,for the benefit on the newer builders.
I first select the plank I'm going to use,and check it for imperfections,
then sand it's face,offer it up to it's resting place,mark the rib positions,then cut the splice joint and drill for pining,if the plank is going above one that is already fixed,I chamfer the bottom edge so that it's a tight fit,then glue and pin into place.
#176 Posted : 18 August 2011 19:42:55
if you look carefully you can see the splice joints,because the splice covers two ribs they are all located at the same position on.
#177 Posted : 27 August 2011 14:54:28
#178 Posted : 27 August 2011 14:57:44
1st.pic is preparing the strake for fixing,the next 2 pics are the clamping and gluing.
#179 Posted : 27 August 2011 15:00:17
Perfect..Just perfect mate...Drool
#180 Posted : 27 August 2011 22:24:20
Nice one mateBigGrin
This page was generated in 0.936 seconds.
