4 Pages <1234>
Wacky races Convert a car Options
#21 Posted : 18 July 2019 22:29:45
Looking very impressive Carl and getting better with every step you make, very well done....Drool Drool
Kev the Modeller
#22 Posted : 19 July 2019 11:08:50
Excellent work Carl, I admire people like yourself who have the knowledge to just design and build something from nothing other than a few sketches - well done! Cool ThumpUp
Per Ardua Ad Astra
#23 Posted : 22 July 2019 03:56:02
More work on the parts of the convert a car.
I need to do the wheels next.Do you guys want to see the step by step process of making a wheel?
#24 Posted : 22 July 2019 07:33:19
Looking really good.
I would be interested to see how tye wheels are made.
Tony
#25 Posted : 22 July 2019 07:50:53
This is a really interesting project. I'm looking forward to seeing some of it as a physical model.
Keep it coming.
Roy.
#26 Posted : 22 July 2019 10:59:29
Nice update CarlBigGrin regards Phil
#27 Posted : 22 July 2019 18:58:16
Nice work Carl, I can see this going into full production soon.Love
#28 Posted : 22 July 2019 22:35:36
This is really coming along Carl, lovely work and great to see something different.... Very interesting seeing the processes...Cool Cool
#29 Posted : 23 July 2019 01:48:06
OK wheel 3d tutorial
here we go;
Step one is I traced around the picture to get the outline of the wheel
Step 2 Starting with the rim I made a second circle inside the first.
Step 3 I made a surface between the 2 circles and then extruded the surface to make a solid rim.
#30 Posted : 23 July 2019 01:54:21
Step 4 starting on the hub.Made a surface from the smaller circle
Step 5 extruded the surface to make a solid cylinder
Step 6 made a surface from the out circle of the wheel hub
Step 7 extruded the outer circle surface to make another cylinder
Step 8 I rounded off the edge of the inner cylinder to mimic the axle
#31 Posted : 23 July 2019 02:02:01
Step 9 Making a wheel hub cap.I drew an arc between the ends of the hub.
Step 10 I revolved the arc around the vertical line to make the hub cap
step 11 I separated the hub cap from the hub.This way I can paint it a different color
#32 Posted : 23 July 2019 02:19:10
Step 12 making the wheel spokes.I drew a line between the hub and the rim
Step 13 I drew some circles around the line to form the walls of the spoke
Step14 I used the loft function to make a surface that was defined by the circles and the line.This was then made into a solid.
Step15 Once I had one spoke I made 5 others using the polar array function.This duplicates an object around a central point.
#33 Posted : 23 July 2019 02:28:00
Step16 making the tire.I drew some reference lines to get the tire width
Step17 I made some curves to make the tire bulge slightly.These curves will form the outline of the tire.
Step18 I used the sweep 2 rail function to rotate the curve around the rim to make the tire.
Step19 The final render of the wheel.It was quit e a few steps, but it only took me about 15 minutes. I will now make a mirror image of the wheel to make the other back wheel and make an axle
#34 Posted : 23 July 2019 11:27:30
That is so skilled being able to produce things as you do.
Its all looking really good.
Tony
Garth
#35 Posted : 24 July 2019 15:34:45
Hi Carl,
I really like your Rhino skills. I also use Rhino, its such an awesome design package.
Kind regards,
Garth
"Measure twice, cut once!!!"
Finished!!! HMS Victory,
Current build: Black Pearl.
Wish list: USS Constitution.
#36 Posted : 24 July 2019 15:38:31
As a slight aside here - did you know Scalextric are soon to release Penelope Pitstop's car...?
They have the rights to Wacky Races so who knows - many others will probably follow...
#37 Posted : 24 July 2019 16:15:52
Thanks Guys,
@Garth Thanks.Rhino is an incredible program.It has a steep learning curve and you have to get your head around the NURBS stuff but it is very powerful.I am currently experimenting with applying textures to surfaces and then using extendrendermesh to make the textures part of the printable model.If I can get it to work it will be perfect for the boulder car in Wacky races and the Arkansas Chugalug wooden planks
@Roy. Oh I hope they do release the pink catcat.If they do I would buy one and scan it to make a bigger version to the same scale as the convert a car.it is quite difficult to model because of all the complex curves.
#38 Posted : 24 July 2019 16:49:59
Carl - have a look on the Scalextric website. They show all new releases for 2019.
Surely before long, they will be showing 2020
BTW... PM coming your way.
nightwisher
#39 Posted : 24 July 2019 21:01:34
This technical stuff is amazing ,it's all science fiction to me and something I'll never get my head around . Can't wait to see it all for real
Had a dream to understand
A single grain of sand
He gave birth to poetry
But one day will cease to be
#40 Posted : 25 July 2019 04:40:33
Almost finished the major sub assemblies.Once this is done I will do a test print to see how it looks
CD
4 Pages <1234>
This page was generated in 0.303 seconds.
