12 Pages «<56789>»
Soliel Royal by Mark Options
mwstratton
#121 Posted : 21 July 2019 10:47:11
Pack 8
After sanding the finished planking smooth, the stem, beak, stern post and keel sections were fitted.
mwstratton attached the following image(s):
Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
w1xq
#122 Posted : 21 July 2019 18:38:13
Wow, looks great Mark!
73 de John
W1XQ (ham radio operator)
Amateur Radio Lighthouse Society
Operator aboard Museum Ship USS Stewart and USS Cavalla
Current attempt: Soleil Royal
Prior Builds: Nantucket Lightship, South Goodwin Light vessel, Natchez Packet Paddlewheeler, Souhern Belle Paddlewheel Towboat
mwstratton
#123 Posted : 21 July 2019 22:29:34
Pack 8
Fitted the 3 molding strips to the hull. The Prow was then fitted. I also built and planked the upper, middle and lower stern gallery decks.
Thanks for all the kind comments
Under the Bench:
DaDokta
#124 Posted : 22 July 2019 07:39:59
Wow! That hull is looking great!
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
mwstratton
#125 Posted : 22 July 2019 19:05:56
Pack 8
Next, I fabricated the hinges and attached the rudder. The 2 Haweses were then built and installed on either side of the prow.
2 x 4 stripes were fitted along the edges of the decks. The molding just below the upper gun ports was added.
Made the 2 catheads and fitted them to the forward corners of the forecastle deck.
That's it for now.
Under the Bench:
#126 Posted : 22 July 2019 20:58:38
That looks fantastic.
You made such a nice job of the hull - just been looking at the pictures again.
Tony
nightwisher
#127 Posted : 22 July 2019 22:33:57
Great job of planking the hull I quite like the variations in the wood ,it makes them look like individual planksCool
Had a dream to understand
A single grain of sand
He gave birth to poetry
But one day will cease to be
#128 Posted : 22 July 2019 23:05:12
Making great progress and a pleasure to watch....Cool Cool
mwstratton
#129 Posted : 22 July 2019 23:43:21
Thanks for stopping by and for your kind comments.
I can't wait to start fitting the decks.
Under the Bench:
mwstratton
#130 Posted : 23 July 2019 07:40:51
Pack 8
I retrieved all of the rails and columns I've built so far. Drove a nail in the bottom of each of the outside posts of each rail and the columns. I then cut off the nail heads to create spikes to hold the fixtures on deck.
The 65mm rails and 3 columns were fitted to the forecastle deck. The rest of the longer rails and last of the columns were installed on the deck just aft of the main mast hole.
That's all for now.
Under the Bench:
mwstratton
#131 Posted : 24 July 2019 06:59:12
Pack 8
Built the 2 heads. I have to say that I don't care for the brass strips provided for the head bands. The material is difficult to work with and extremely hard to glue in place. They will be fitted later. Next I assembled the beakshead. Made the 20 rungs of the bow bulkhead ladders and glued them in place.
Moving on...
Under the Bench:
mwstratton
#132 Posted : 26 July 2019 06:25:40
Pack 8
I made half of the gun port doors. 8 small columns were built. The beakshead was fitted and glued to the bow deck and the prow.
THIS COMPLETES PACK 8
I'll be back in about 2 weeks.
Under the Bench:
#133 Posted : 26 July 2019 07:06:47
some very nice work again on your build.
Tony
Oliver
#134 Posted : 27 July 2019 21:56:10
Amazing build, very nice attention to details. Looking forward to see more updates Mark. It helps me a lot since I'm just an issue behind you.
Oliver.
#135 Posted : 27 July 2019 23:00:41
Certainly powering ahead Mark and making excellent progress too. Keep going like this and you'll end up with a stunning build..... very well done....Drool Drool
#136 Posted : 28 July 2019 08:56:25
Great build Mark,Love Drool I admire anyone building these kitsCool
Very nice work.
DaDokta
#137 Posted : 30 July 2019 10:58:28
Wonderful build so far, Mark!
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
mwstratton
#138 Posted : 15 August 2019 11:14:57
Pack 9 - Stage 92
In this stage I built Some of the gun port doors. They were painted red on the inside and stained walnut on the outside.
A ladder was assembled and cut into 2 sections, each 4 rungs tall. They were fitted to the mid deck leading to the gunwales.
Under the Bench:
mwstratton
#139 Posted : 15 August 2019 11:21:46
Pack 9 - Stage 93
This stage found me building the rail along the midship gunwales. 2x7mm walnut strips and 14 brass columns were used. 2x2mm molding strips were added fore and aft of the bottom rail. The top rail ran from the catshead to just in front of the first round gun port.
Fitting out the decks is my second most favorite part of ship modeling. (First is actually rigging)Huh Love
Under the Bench:
#140 Posted : 16 August 2019 00:00:32
Looking good, lovely work....Cool Cool
12 Pages «<56789>»
This page was generated in 0.286 seconds.
