R2 Options
R2D2Nut
#1 Posted : 21 July 2019 22:57:14
As soon as I am through building R2 (2 mnths) I am thinking about build a RC X-Wing that is scale to R2 and allows R2 to be seated in it. BigGrin Sounds good anyway LOL
#2 Posted : 21 July 2019 23:16:13
BigGrin Like the idea but your talking a half scale X-Wing here. I presume your thinking of using a minimum of 4 mini turbo jets here or as many as you can fit in each engine housing. Also with a R/C model of that size you will need to add double control systems one as a back up on a different frequency if one fails. The weight of the battery packs and fuel tanks could also be a problem to overcome. I like the idea though and good luck with your projectDrool Cool
R2D2Nut
#3 Posted : 21 July 2019 23:21:38
Of course she should be packing 4 little monsters ThumpUp Weight? Ha! just the weight of R2 will be a big hurdle alone BigGrin
tschwand
#4 Posted : 22 July 2019 18:44:20
Would be an interesting project, but based on the measurements of the X-Wing build here, a 1:2 scale X-Wing would be about 22' long and 19' across the wings! Good luck with that.
R2D2Nut
#5 Posted : 22 July 2019 19:02:54
BigGrin BigGrin BigGrin BigGrin
About a Cesna size
taitoo
#6 Posted : 22 July 2019 22:23:25
Rank: Newbie
About a Cesna size
Look up Rutan VariEze and add another wing. BigGrin
This page was generated in 0.100 seconds.
