11 Pages «<56789>»
Vw Golf 2 GTI Tuned 1/8 Build Options
#121 Posted : 22 July 2019 08:32:11
Some amazing work going on here. You clearly know your Golf GTI's...
As I said - amazing. Keep it all coming.
Roy.
#122 Posted : 22 July 2019 09:59:06
Great work as always Francesco Cool good to see ithis progressing.
frah2o
#123 Posted : 22 July 2019 10:14:25
Roy.
Thank to much ROy.....watching your impressive building and improvent on your models is a great pleasure receive this message from you. Blushing
Thnaks and i continue doing my best on this GTI.
Thanks so much Al...i hope to made good everything in my mind for this project. BigGrin
frah2o
#124 Posted : 23 July 2019 07:41:51
I continued with inlet system.
I added the idle bypass adj screw to the throttle body. Next step (i missed will be to add the hose to fuel pressure regulator for preheat valve)
I painted the throttle in flat alluminium and i fix it to intake hose with a hidden screw. Finally i add shrink tube and alu tie.
I remade the hose from the idle air stabilizer to inlet duct. I made with a new pond wire coated with shrink tube.
I added real m 1.4 bolt on alternator bracket than i fixxed it on engine
Finally i start an hard work on exhaust manifold.
The kit give a curious manifold with only a duct.
I added the missing 3 duct and i “solded” them with Ciano and bicarbonate.
Nex step i’ll moulded the new manifold and I’ll try to made the flange to head (very hard for space)
#125 Posted : 23 July 2019 07:52:50
Amazing work, looks very real.Love
frah2o
#126 Posted : 07 August 2019 07:28:30
After some holidays i continued with engine.
I remade the hose coolant. I simulated the use of metal hose with silicone joint
After this I started to made the first part of engine harness. i self made the bracket fixxed on gearbox to fix the plug of harness
To this connection i plugged the wire for:
- oil pressure
- oil temperatur
- knocking sensor
- alternator cable
- water temperatur
- engine temperatur
- distributor cable
I also self made another wiring part totally missed
- idle motor cable
- water tempaeratur head
- rail injection cable
To this harness i also add the wiring of MAF sensor
Finally i added the wiring no starter motor
#127 Posted : 07 August 2019 08:58:22
Some very neat work.
You really know your subject well.
Tony
#128 Posted : 07 August 2019 10:22:57
Very nice detailing on the engine. Love Drool
#129 Posted : 07 August 2019 10:54:20
As I said before, this is great. You clearly know about the Golf GTI...
Roy.
Kev the Modeller
#130 Posted : 07 August 2019 18:47:07
Fantastically detailed work as always from you Francesco, I love following your builds - keep it up! Drool ThumpUp
Per Ardua Ad Astra
frah2o
#131 Posted : 08 August 2019 07:24:59
Roy.
Thanks to all mates. This project is just a little bit easier than Delta because i have referenceres directly in my garage LOL
Thanks to all for appreciations. Blushing
frah2o
#132 Posted : 08 August 2019 07:42:51
I start to work on radiator. In the kit the radiator was totally absent, just only fairing and fan. Watching the engine is really poor and bad view. Bored
On the real radiator fairing the vent are opened.
I opened these vents hole to evacuate the cold air (in the future i’ll decide if mantein rubber flap with alu stopper like on original vw fairing or selfmade a new exhaust vent as i saw in some vw meetings)
I used a radiator from an 1/10 rc and i adapted it with lego brick to the shape of fairing....now it seems just little bit a cooling radiator
I modified the radiator for the future extra air inlet hose for the extra oil cooler. The cut side of radiator will be remodeled with some styrene
I holed inside engine bay for front brake lines and fuel lines
Finally i give 2 primer coats to underbody and engine bay. Tomorrow i painted it with new color: sky blue ral 5015
#133 Posted : 08 August 2019 17:25:46
Great work on the rad Drool Drool all looking goodBigGrin regards PhilCool
admin
#134 Posted : 08 August 2019 19:21:34
This is looking simply outstanding!
Please continue posting!
#135 Posted : 08 August 2019 22:35:05
Fabulous work throughout and a pleasure to see.....Cool Cool
frah2o
#136 Posted : 09 August 2019 08:54:46
Thanks very much for your support and apprecciation. I'm very happy that you like this project.
I'll do my best also for your support, Thnaks Blushing BigGrin BigGrin
Before to paint chassis in blue, i tried to selfmade and replicate with iron wire the brake lines.
Now that I find the correct shape of brake lines, i come back to work on master brake cylinder to add some joint and a better finish look.
Suddendly the 3 paint coat of blue to chassis and engine bay. I choose this color because is too similar to "Blau color concept golf MK3" and because i like it very much.
#137 Posted : 09 August 2019 10:15:42
Excellent build, love watching this come together.Love Love
frah2o
#138 Posted : 10 August 2019 18:56:54
Thanks too much Mark
I continued the work on engine.
After adding the 3 missing exhaust ducts, i painted the manifold in alu and 2 final smoke coats.
To give some burn look i used tamiya powder wheatering.
I also wrapped the warm air filter duct with aluminium foil.
I started the modded work on radiator fairing. With modified lego brick i selfmade a new cold air extractor.
I also add weld lines, new joint hose and metal mesh.
I little detailed the cranck, waterpump and alternator pulley. With insulating tape i self made the belt.
Finally i holed and insert some pins for the new hose connection for MAF sensor.
Finally a pre test fitting un engine bay.
frah2o
#139 Posted : 13 August 2019 10:17:27
Some few progress but a big solving problem with engine (the extra add coolant hose to heater core)
In the kit was present only one hose that have a particular shape. This hose creates some impeding (specially to extra brake lines added previous)
So i decided to remade the new hoses using a sprue.
To maintain the hose in position, i made a hole and i insert a pin in each hose (after a little moulding job)
I dry fitted the hose and i checked the clearance on firewall for extra add of brake lines.
It’s seems fits good, next step painting and adding silicone hose joint.
frah2o
#140 Posted : 14 August 2019 07:59:43
I finally fitted engine inside bay.
Before fitting engine i finished job on master cylinder brake. I add som nut to ricreate the nut joint for brake lines
I used some stripes of insulating tape to create fixing grommet for brake lines mounted on firewall.
With styrene i selfmade the exhaust heat shield and finally i taped it with alu tapes.
I also selfmade the bracket for vapor oil canister, and i also added 2 nuts.
I used tamiya braided hose for 2 fuel lines, and i holed the firewall to insert the first part of engine wiring.
Finally i fixxed the engine and i connected the vapor oil canister to vent joint on rocker cover.
Guest (19)
11 Pages «<56789>»
This page was generated in 0.566 seconds.
