7 Pages «<34567>
Malc's Fiat 806 Options
Kev the Modeller
#81 Posted : 22 August 2019 19:53:46
Lovely work as always Malc, looking very realistic. I love the brass pipework, those red magnetos and the tape round the steering wheel - does the tape come with the kit or is that another of your excellent examples of scratchbuilt detail? It does look very correct for the period and nicely done too!
Looking forward to the next stage with eager anticipation! Drool ThumpUp
Per Ardua Ad Astra
#82 Posted : 22 August 2019 22:52:41
That does look rather good, excellent work.Love Drool
Garth
#83 Posted : 23 August 2019 10:00:42
Hi Malc,
Lovely update. It's just getting better & better!!!
Kind regards,
Garth
"Measure twice, cut once!!!"
Finished!!! HMS Victory,
Current build: Black Pearl.
Wish list: USS Constitution.
RM1
#84 Posted : 26 August 2019 17:24:22
Thanks to all for looking in and the kind comments.
@Kev. The taping of the steering wheel is part of the kit. There's a square of fabric which has to be cut into 2mm strips and bonded on. Quite pleased with the result.
Malc.
RM1
#85 Posted : 04 September 2019 10:13:01
My attention has turned to the bodyworkBigGrin . The supplied parts are quite rough with loads of flash, mould lines and sink marks. They are made from a very poor looking red plastic. I spent quite a bit of time cleaning them up and because I want a dark red finish ( not too glossy ) I have primed them with a flat black.
Malc.
RM1
#86 Posted : 04 September 2019 10:17:47
The radiator is in 4 parts. I sprayed on the number 15 ( template in kit ) and gave the outside a Brass finish.
Malc.
RM1
#87 Posted : 06 September 2019 16:32:27
Colour coat of Tamiya TS8 ( italian red ) but the black primer has darkened it to my likingBigGrin
Malc.
#88 Posted : 07 September 2019 00:53:14
Drool Drool Drool Drool Drool BigGrin Looking good MalcCool
#89 Posted : 07 September 2019 10:07:57
Fabulous Work, great seeing this come together.Love Love Love Drool Drool
andali15
#90 Posted : 07 September 2019 15:12:44
Excellent work. Enjoying following your build. Andy.
RM1
#91 Posted : 10 September 2019 09:11:39
Thanks for looking in and the kind comments guys.
Malc.
#92 Posted : 10 September 2019 10:44:12
Cool All looking good and nice work Malc Cool
Kev the Modeller
#93 Posted : 10 September 2019 20:13:16
Fantastic work going on here as always Malc. Love all of the brass bits and I agree with your choice of black undercoat for darkening the red, it's certainly done what you intended and looks great! Drool
Very well done. ThumpUp
Per Ardua Ad Astra
Garth
#94 Posted : 13 September 2019 09:49:08
Hi Malc,
Such inspiring workDrool Drool Drool
Awesome work as usual.
Kind regards,
Garth
RM1
#95 Posted : 17 September 2019 09:27:36
Thanks Garth.
RM1
#96 Posted : 17 September 2019 09:35:50
The instructions for this build are generally clear about the order of assembly but I would recommend that if fellow builders tackle the 806 that they plan well ahead for the construction. Some of the threaded plastic parts have poorly moulded screw threads which take brass fasteners. Generally these don't fit well and there is a constant risk of breaking the plastic. Even a die nut is not effective as the parts are so delicate. ( sizes M1.4 and M2 mm ).
A typical example is the pair of brake lever arms mounted on the inside of the rear axle assembly. The instructions show these being added at a late stage once all the rear suspension is in place. that would be very stressful !! I put them on before the main assembly.
Malc.
RM1
#97 Posted : 17 September 2019 09:39:56
Another "silly" feature is the retention of the fuel tank on a single self tapping screw. No amount of clamping ( or hole enlarging ) stops the screw from splitting the carefully prepared tank Crying .
I tapped the hole for an M3 and used a machine screw.
Malc.
#98 Posted : 17 September 2019 09:57:48
Moving ahead beautifully.
I bet it will look a stunner when complete, particularly if you put it alongside some recent F1 cars...
Roy.
#99 Posted : 17 September 2019 16:44:25
Hi coming along beautifully, be a model to be very proud of once complete.BigGrin
#100 Posted : 18 September 2019 07:33:33
Lovely work Malc.Love
7 Pages «<34567>
This page was generated in 0.090 seconds.
