4 Pages <1234>
My Build to Date Options
#41 Posted : 15 August 2011 18:00:42
Its not bad to have abilities stretched as it is what keeps a build interesting, well done CMB Cool
#42 Posted : 16 August 2011 19:34:48
looksr real goodBigGrin
#43 Posted : 16 August 2011 20:40:41
Brilliant mate...a really fantastic job there...keep it up!! ThumpUp
riff-raff
#44 Posted : 16 August 2011 22:10:53
Nice build mate
Built:
CMB
#45 Posted : 17 August 2011 18:44:17
Thank guys for all your kind words.
Special thanks to Mr T for his build diary and tips, without these I would not have been able to achieve the results as shown so far.
I just hope the mast building goes as well when I get to that stage.
Thanks for looking and happy building to you all.
CMBBigGrin
#46 Posted : 17 August 2011 18:50:13
No need to thank me CMB, its what I do and only too happy to help you on your way Cool
#47 Posted : 02 February 2012 17:00:18
Realy great build CMB. Ian Cool
CMB
#48 Posted : 10 February 2012 16:46:22
Now into February and the build continues, albeit somewhat slowly.
Since my last update I spent some time tidying up the gun ports as they did not look square when the hull was sitting on the keel, this took a little time but I think well worth the effort.
Painted the hull as per the instructions and masked off the various areas in order to paint the bands.
Once painted some defects in the hull became obvious and a little light sanding was required to rectify
Next came the fitting of the steps and fenders, the steps in particular I found very fiddly but managed to line them by eye and I am happy with the end result.
At the moment I am not really happy with the copper paint finish so a better brush is on my shopping list next time I am in the nearest art shop.
All the masking tape is still in place until the painting is complete
The fighting top was built and painted as per the magazine, although I had to add 2mm inserts in order to have enough material to drill the smaller holes 24mm in from the sides, I hope this does not come back to bite me later in the build.
CMB attached the following image(s):
#49 Posted : 10 February 2012 17:04:09
Really great work CMBBigGrin Regards MikeBigGrin Cool
#50 Posted : 10 February 2012 18:55:45
Coming on well CMB Cool
You'll likely need to enlarge the mast top holes when it comes to inserting the bound deadeyes at 94.
CMB
#51 Posted : 11 February 2012 10:21:28
Thanks for that Mr T.
I will have a look at that over the weekend.
CMB
Ger C
#52 Posted : 11 February 2012 16:58:18
Looks very good to me, you must be v happy,
Ger
#53 Posted : 13 February 2012 11:17:23
Looking good CMB, your build is looking great. Slow is good. Makes for a better model and allows you to think before you build. Less kit bashing later when you have a better plan.
CMB
#54 Posted : 21 February 2012 12:50:45
For those who have glanced at my build diary over the past few months you will have no doubt noticed that I had skipped over the mast building/assembly instructions and gone on to paint the hull. The reason being that I was not at all sure if I was up to the shaping and carving that was required.
Well I could not put it off any longer, so purchased a length of 10mm dowel from my local timber merchant as I expected to have several attempts and using the supplied dowel had my first crack at the lower main mast. Surprise, surprise it worked out OK and the other two sections were completed as per the magazine and Mr Ts instructions. Photographs taken and I am very happy with the result
The next challenge will be the rigging, I have opted for the 'no sails' & Standing rigging but she who must be obeyed says that I should fit the sails, time will tell.
Now to tidy up the hull painting before starting on the next mast.
If anybody spots a clanger shout loud before I screw up.
Happy building to you all
CMBBigGrin
MAST 1.jpg (424kb) downloaded 82 time(s).
MAST 2.jpg (441kb) downloaded 76 time(s).
MAST 3.jpg (476kb) downloaded 69 time(s).
MAST 4.jpg (441kb) downloaded 69 time(s).
MAST 5.jpg (372kb) downloaded 69 time(s).
MAST 6.jpg (259kb) downloaded 75 time(s).
#55 Posted : 21 February 2012 14:58:41
Very nice job CMBBigGrin Regards MikeBigGrin
StefanDV
#56 Posted : 22 February 2012 08:07:38
Grest pictures CMB - your build is looking splendid! Drool
z8000783
#57 Posted : 22 February 2012 08:29:46
Groups: Unapproved
Well done for jumping in.
John
CMB
#58 Posted : 22 February 2012 12:37:07
Thanks for the nice comments guys.
I am now really enjoying this build and wish that I had started years ago.
May have a go at the Mississippi Steam Boat next.
Cheers all and happy building
CMBBigGrin
CMB
#59 Posted : 25 February 2012 13:09:22
Since my last post I have glued the top two sections together and fitted the rigging blocks.I found it easier to line up the mast this way than by starting with the lower section,and the two seperate sections can now be stored easily until it is time to fit to the hull.
I am now working on the mainyard and remenber that there were some issues with the brass wire being very brittle, had a look at SOBs solution and think that could be the way to go. Anybody know what size cord should I use?
CMBBigGrin
#60 Posted : 25 February 2012 13:29:05
BigGrin Hi CMB
Doing a fine job there m8,its strange when you keep putting stuff off then try it and suprise yourself with the results of the chalenge involved,great stuff keep it up
4 Pages <1234>
This page was generated in 0.703 seconds.
