Joined: 09/12/2013 Posts: 577 Points: 1,748 Location: smethwick england
Have to agree,those seats do look amazing Man he took his time in the sun Had a dream to understand A single grain of sand He gave birth to poetry But one day will cease to be Greet the last light of the library...We were here!
Hi Roy, I think the team of horses will be hard to find,but I am working on the final pictures when finished thanks for looking in. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi Nightwisher,thank you for looking. Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Making and assemble of the Winch Box: The winch box will be were the driver will sit,this will be made from wood and leather as you will see in the next post.The main frame is made from ply which has to be turned up at the front to fit the foot plate,also it will be fitted with a internal door which has a brass handle.there are two small seats to upholster should be good fun.  Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
 This picture shows marking and cutting the Leather side to shape. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Great to see another update of this one Trev and a fab job you're doing too..  .. Look forward to seeing more.... Regards Alan
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,271 Points: 22,120 Location: Northamptonshire, England
Lovely work Trev as always. Coming together very nicely. Mark Regards Markwarren (Mark) Admin
@ Alan @ Mark Thank you for looking in, as you can see the Winch assemble is progressing at a slow pace but there is a lot to build and think about, the hard parts were cutting / fitting and folding the Leather side parts this will be in my next post. Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
 The Winch build has moved on to this stage,floor and back have been added also the sides Left-Right,next will be the main foot rest (5 pieces 1.5x 2mm)then the roof and more wooden side bits all hand made. Trev. ps: Winch is were both drivers sit. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Looking good Trev, very neat and tidy work. Look forward to seeing your next update..... Regards Alan
Nice work Trev. Mark Regards Markwarren (Mark) Admin
@ Alan @ Mark Thanks for having a look and your nice comments,next will be more on the Winch box regarding the building and soldering of the the brass railings. More soon Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi Trev, Looking really good. Don`t know if these would be close enough in scale or of an acceptable price, but they do horses in 1:9 scale and as an extra, harness sets as well. https://kulpmodelhorsest...com/1.9ScaleHorses.html
Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Great to see you back on this one Trevor. And very neat it all looks as well. You made a lovely job on the inside door "buttons". Hope it all continues well. Tony Happy Modelling
Hi Derek,I will be looking into your find with the 1.9 horses as they will look the part,as with the back ground that I am thinking about. Many thanks for that Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi Tony, Thank you for looking in and your nice comments,I have moved on a pace now just finished bending and soldering the hand rail,which forms a small rail around the drivers,air brushed black today hope to post tomorrow. Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
UPDATE:THE WINCH. Cutting and Soldering Hand Rails. To make two hand rails take the 0.2mm brass rod, cut two 85mm pieces then shape into 3 bends (8mm 21mm leaving 56mm length,now solder and clean up, when finished make one more to match the first. With the same 0.2mm rod make the central rail this is the one between the cushions, this one you have to adjust to the length of the winch box.  Brass rods ready to be Soldered.  Having fun.  This shows horizontal bar to be soldered.  This bar shows where the leather dust sheet will be stitched on.  Finished and painted Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Nice work Trev, you’ve done a great job of straightening that brass if it came on that reel. Mark Regards Markwarren (Mark) Admin
Thanks for looking,brought some brass rod Mark that would have sent me nut's I have tried to do that be for with no luck, Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi Trev You need to get a brass wire straightener. Will save you buying brass wire when its included in a kit. https://www.ebay.co.uk/i...8a41:g:UuEAAOSwowddA5UU
From a previous thread you can see the results, as I have used it on 1.5mm wire as shown in post #6: https://forum.model-spac...spx?g=posts&t=23056
Guest (14)
