Joined: 30/05/2017 Posts: 29 Points: 93 Location: USA
I'm finishing up the build, and have found that the cockpit glass for the Millenium Falcon doesn't come close to fitting the cockpit windows at all. I dug through the forum and it seems that issue 40 should have had a new cockpit frame in it that fits the glass (but I never received one). Thanks for any advice. Shawn Current Builds: R2D2, Millenium Falcon
stwood6 wrote:I'm finishing up the build, and have found that the cockpit glass for the Millenium Falcon doesn't come close to fitting the cockpit windows at all. I dug through the forum and it seems that issue 40 should have had a new cockpit frame in it that fits the glass (but I never received one).
Shawn Hi Shawn The revised cockpit that came in issue 40 also came with the glass that fits that frame. The original cockpit which came in issue 6, fits the glass that came in issue 46. If you are using the original cockpit and the glass doesn’t fit you’ve got the glass that came in issue 40 along with the revised cockpit. Check issue 46 for the right glass. If you want the revised cockpit, issue 40, and can’t find it, contact c/s for a replacement. Hope that helps. Mark Regards Markwarren (Mark) Admin
Thanks for the info Mark! Current Builds: R2D2, Millenium Falcon
