13 Pages «<23456>»
Micks 1/200 battleship bismarck Options
#61 Posted : 28 September 2019 13:18:57
Issue 28
Here we extend the hull with another plate,attach various parts to the forward bridge deck,and install the navigation lights.do not cut off the clear long tab to the navigation light as this is needed to reach the bulb, previously installed,they fit in with this clear tab at the same angle as the pins on the navigation light holders.sorry not many pics of this stage as my phone seems to have dumped some of them. Cheers mick. BigGrin
#62 Posted : 28 September 2019 13:29:35
Another very nice update Mick, lovely progress....Cool Cool
#63 Posted : 28 September 2019 13:53:19
Issue 29
Here we get the bridge deck and lower mast deck,plus bits of decking and the bridge light and bulb to install, plus couple of guard houses to fit to bridge deck.Tony you asked me what I thought of the wooden decks parts,to me they are nicely moulded but bit all same colour, so I gave mine a brown wash just to bring the detail out a bit.then screw these 3 parts together. Cheers mick BigGrin
#64 Posted : 28 September 2019 14:02:49
Issue 30
Here we get another hull plate, and the first rangefinder, just pay attention to direction of parts on rangefinder as can easily be but on wrong way around. If in doubt put it on superstructure before you glue the top on, finally few shots what we have so far,till me next parts arrive that's it for now.cheers mick.BigGrin
#65 Posted : 28 September 2019 17:23:32
Taking shape really nicely Mick.Love Cool ThumpUp
#66 Posted : 28 September 2019 19:52:23
BigGrin Looking good and nice work MickCool
Garth
#67 Posted : 30 September 2019 06:21:52
Hi Mick,
Coming along nicely.
Kind regards,
Garth
"Measure twice, cut once!!!"
Finished!!! HMS Victory,
Current build: Black Pearl.
Wish list: USS Constitution.
#68 Posted : 18 November 2019 11:46:35
Hi had bit of delay on this as post office tried to deliver parts when I was out and left no red card,so they got sent back,and had to sort out redelivery, anyhow got next 4 issues eventually
Issue 31
Here we attach another hull plate, and build up and glue on the second rangefinder, cheers mick.BigGrin
#69 Posted : 18 November 2019 12:01:12
Issue 32
Here we attach another hull plate, then glue on the 2 liferafts the yellow bits,glue on vent to the rear on forward superstructure, glue 2 hatches to the deck,glue 2 bits to front of bridge,add 2 more small vents,add the 4 etch guard rails to protect the navigation lights, a few etch ladders,and the small etch platform on one side,the etch is thick,and don't come off the etch frame easily, I weakened the tabs with me dremmel tool first, then cut through with knife, cheers mick. BigGrin
#70 Posted : 18 November 2019 12:05:31
Issue 33
Hardly worth mentioning, it's just attach label to radar motor, cheers mick.BigGrin
#71 Posted : 18 November 2019 12:32:58
Issue 34
Some small fiddly parts on this one,first of all we glue in 6 lockers 3 each side to the radar control centre, then glue in the 2 radar arms to the radar unit,then put in the 3 gears for the radar, then attach the motor from the previous issue,then it's glue on the 3 etch handrails to the radar,then 2 etch ladders to the control centre, a further 2 etch ladders are added to the forward superstructure behind the rangefinders, then glue on the radar antenna and screw on the radar Base to top of control centre, then it's glue on the small details on the roof of the control centre and radar, then finally glue the radar on top,that's it for now, thanks to all who looked in and left comments much appreciated. Mick. BigGrin
#72 Posted : 18 November 2019 20:18:04
its looking amazing Mick.Were the photoetched parts prepainted?
#73 Posted : 18 November 2019 20:22:37
BigGrin All looking good and nice work MickCool
#74 Posted : 18 November 2019 21:42:39
Hi Carl yes etch all comes prepainted, just need to touch up ,the cut off points,not clue what grey they used,but as only be tiny dots of paint ,shade matching perfect not going to matter that much.thanks Andy for looking in to.cheers mick. BigGrin
CaptnBirdseye
#75 Posted : 19 November 2019 17:45:59
Rank: Superelite
BigGrin Coming together well Mick ThumpUp
#76 Posted : 20 November 2019 08:53:57
Coming on very nicely Mick.Love
#77 Posted : 08 December 2019 17:20:27
Hi thanks to all who looked in and left comments much appreciated
Issue 35
Here we add all the parts left over from issue 34,I had already fitted the control centre previously, it's a tight push fit so I left it in place while fitting in the new bits,we then fix the superstructure deck,to the bridge deck then fit another hull plate and make up the next bit of stand.BigGrin
#78 Posted : 08 December 2019 17:24:56
Issue 36
Dull issue this one just attach label to motor.BigGrin
#79 Posted : 08 December 2019 17:33:32
Issue 37
First of all we attach another hull plate, then assemble the radar gearbox, fix the top on this,and add the foretop command post attachment to the rear face of radar, also the motor is fixed in place cheers mick. BigGrin
#80 Posted : 08 December 2019 17:50:36
Issue 38
First of all we attach another hull plate, then glue the bit of decking into the foretop command post gallery, next I glued in the 3 small parts on the roof of the previous assembled radar,easier to do these now than when the rangefinder arms get in the way, next fix the 2 rangefinder sockets to the radar,then glue in the rangefinder arms paying attention to the way they face,and note the 2 holes in them need to be on top,the instructions fail to mention these holes,then glue on the door and lockers to the back of unit,then glue the radar unit to the gallery that's it for now, cheers mick. BigGrin
13 Pages «<23456>»
This page was generated in 0.389 seconds.
