12 Pages «<9101112>
Soliel Royal by Mark Options
mwstratton
#201 Posted : 24 October 2019 08:22:12
Pack 11 - Stage 122
I finished the decorations of the lower gallery balcony in this stage.
Getting closer to the finish.
mwstratton attached the following image(s):
Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
mwstratton
#202 Posted : 24 October 2019 09:39:24
Pack 11 - Stage 123
This stage was all about decorations on the port and starboard sides of the upper gallery.
The central lantern mount was also fitted.
Under the Bench:
mwstratton
#203 Posted : 24 October 2019 09:58:41
Pack 11 - Stage 124
The port and starboard lantern mounts were fabricated and fitted to the poopdeck gunwales. The poopdeck handrails were also fitted.
Under the Bench:
mwstratton
#204 Posted : 26 October 2019 06:40:21
Pack 11 - Stage 125
The port and starboard gallery decorations were finished .
Belaying pins were added to the pinrails on the main, fore and quarterdecks.
The stage is complete.
Under the Bench:
#205 Posted : 26 October 2019 09:13:26
That is looking sooooo good.Love Love Drool
mwstratton
#206 Posted : 29 October 2019 23:53:35
Pack 11 - Stage 126
The man and leaf decorations were fitted to the port and starboard side galleries along with the bottom decorations.
The large stern decoration was glued in place.
I built up the 4 counter timber decorations with left over hull planking strips then shaped them to match the curve of the transom.
The gun port lids were finished with eyepins and 3mm rings then fitted in place to the stern gun ports.
This completes the stage.
Under the Bench:
mwstratton
#207 Posted : 30 October 2019 00:00:43
Pack 11`- Stage 127
This short stage consists of cutting 6 eyepins to 2mm length. small holes were drilled in the marked locations on the transom and rudder. The eyepins were fitted into the holes and glued in place.
After the glue dried, a length of chain was attached to the eyepins with 3mm rings.
This completes the stage and Pack 11.
Really looking forward to the next pack. I love mast assembly and rigging.
Under the Bench:
#208 Posted : 30 October 2019 09:21:23
Coming along very nicely Mark, lovely work....Cool Cool
Sticky Wickett
#209 Posted : 01 November 2019 16:05:23
Just caught up with this Mark. Incredible work!Love
Phil W.
mwstratton
#210 Posted : 13 November 2019 09:52:15
Pack 12 - Stage 128
Starting the final pack. This will be my favorite part of the build. Fitting the Masts and rigging.
Stage 128 starts by building the 3 lamps for the stern.
Using eyepins, the oar locks on the 2 launches are fabricated. The launches were then glued to the boat rack built earlier. the rack was then fitted to the main deck.
Stage Complete.
Under the Bench:
mwstratton
#211 Posted : 13 November 2019 09:59:55
Pack 12 - Stage 129
The bowsprit was cut to length and tapered according to the plan. 6 cleats were made and glued to the bowsprit.
Ribs were added to the bowsprit top.
The gun port lids were finished with eyepins and 3mm rings. The lids were then fitted to the gun ports.
Stage Complete.
Under the Bench:
mwstratton
#212 Posted : 13 November 2019 10:13:11
Pack 12 - Stage 130
The bowsprit top trestletrees and crosstrees were built and attached to the bottom of the bowsprit top.
The lower bowsprit mast was cut to length and attached to the bowsprit along with the knee. The bowsprit top was fitted over the mast.
The top mast was cut to length and fitted to the lower mast and bowsprit top, using the mast cap.
The top trees were assembled and the topgallant mast was cut. These assemblies were fitted to the top mast along with the top cap. The top ball was added to the topgallant mast.
Stage Complete.
Under the Bench:
mwstratton
#213 Posted : 13 November 2019 10:23:51
Pack 12 - Stage 131
The foremast was cut to length and shaped to the plan. The foretop and trees wre assembled and ribs added.
The rubbing paunch and cheeks were added to the mast. Eight bindings were added to the mast. The bibs and foretop were fitted to the mast.
The deck guns were assembled and glued to the deck. The gun rigging was then added.
TIP: Instead of gluing the eyepins for the gun rigging to the bulwalks first, I find it easier to tie the rigging to the eyepins FIRST then gluing them to the ship.
Stage Complete
Under the Bench:
mwstratton
#214 Posted : 13 November 2019 10:28:35
Under the Bench:
mwstratton
#215 Posted : 13 November 2019 10:35:57
Pack 12 - Stage 132
Following the bowsprit plan, I fitted all the blocks to the bowsprit.
Slots were cut into the sides of the grates next to the bowsprit to make room for the gammoning.
The bowsprit was fitted to the bow of the ship.
2 sets of ballels were fitted to the fore deck and the poop deck.
The launches were lashed to the boat rack.
Stage Complete.
Under the Bench:
#216 Posted : 14 November 2019 08:52:49
Excellent work Mark, she’s really taking shape now.Love
mwstratton
#217 Posted : 27 November 2019 10:15:06
Pack 12 - Stage 133
This stage started by building up the upper parts of the foremast and fitting them to the lower foremast.
The spritsail yard and sprit sail top yard were made and rigged with blocks per the bowsprit plan.
The yards were then fitted to the bowsprit.
Stage complete
Under the Bench:
mwstratton
#218 Posted : 27 November 2019 10:23:50
Pack 12 - Stage 134
The reminder of the stern bling was fitted. The 3 lamps were also glued in place.
The foremast yards were fabricated and fitted with blocks, foot ropes and parrels.
The foremast was rigged with the appropriate blocks per the foremast plans.
Foremast was then fitted to the hole in the forecastle deck and glued in place.
Stage complete
Under the Bench:
mwstratton
#219 Posted : 01 December 2019 02:31:59
Pack 12 - Stage 135
The Main mast was fabricated and stepped to the hull. The mainmast yards were fitted and rigged with the appropriate blocks.
The headrails were then fitted and the 4 columns were attached to each side.
The stage was completed.
Under the Bench:
mwstratton
#220 Posted : 04 December 2019 05:01:18
So with the next stage, the fun begins! The rigging.
There is something about all the lines and sheets that just bring a tall ship model to life.
I'm sharing a photo of my favorite rigging tools. Hope someone finds these common items useful.
Under the Bench:
Guest (9)
12 Pages «<9101112>
This page was generated in 0.424 seconds.
