25 Pages «<45678>»
Goddo's Build Options
goddo
#101 Posted : 24 October 2019 17:14:43
I finally completed the upper planking and as the bow planks were quite close to 14mm above the deck supports, I added an extra narrow strip. Closed off the gallery support brackets and taped in some polystyrene packing so that the lower hull can be planked.
Any comments, good or bad please, would be appreciated.
goddo attached the following image(s):
z8000783
#102 Posted : 24 October 2019 19:11:20
Groups: Unapproved
No comments at all. It looks great, Chris.
#103 Posted : 24 October 2019 22:49:11
Coming along nicely Goddo, nicely done....Cool Cool
Garth
#104 Posted : 25 October 2019 07:23:41
Hi Chris,
Looking good!!! It's a good idea using all that polystyrene reinforcing.
Kind regards,
Garth
"Measure twice, cut once!!!"
Finished!!! HMS Victory,
Current build: Black Pearl.
Wish list: USS Constitution.
#105 Posted : 25 October 2019 09:14:53
Looking excellent.Love
goddo
#106 Posted : 06 November 2019 14:05:37
I have been lining the gun ports using 1.5 x 4mm as supplied. All was fine on the port side.
Then I made a mistake. I lined a complete row of starboard gun ports without looking at the planks too closely
until I tried my little home made 9mm x 9mm guage in the finished openings. I couldn't understand why it just wasn't passing through until I looked again at the planks. They were 2mm thick so now I have the job of sanding back the openings to get them to 9mm square. At least it was only one row.
Lesson learnt: Even though the package says they were 1.5mm, always check them first.
gun port lining.jpeg (30kb) downloaded 65 time(s).
gingerale75
#107 Posted : 07 November 2019 11:29:43
All looks great to me, nice build.
Dont worry, we all made mistakes. Until you can corrct it without too much damage, it’s OK. Cool
Happy building!
Laszlo
Finished builds: HMS Victory, HMS Victory Cross-Section
goddo
#108 Posted : 10 November 2019 18:23:47
Update photos now that first four rows of lower planking are complete.
Gun ports all lined, including the two beneath the gallery.
#109 Posted : 10 November 2019 21:28:48
Well done on getting all your port openings lined.
That is a massive load of work and one of the areas that does get tedious.
Your getting on really well with your build.
Hope it continues well.
Tony
goddo
#110 Posted : 10 November 2019 21:33:07
Thanks for your comments, Tony.
I actually found lining the ports quite therapeutic and only worked on it when I really felt like it,
rather than giving myself set periods of time.
A couple more progress photos here.
hull 1.jpeg (33kb) downloaded 60 time(s).
hul 2.jpeg (52kb) downloaded 59 time(s).
#111 Posted : 10 November 2019 22:32:53
Must say i really like your work space.
I am limited to table sharing so time gets taken up with setting up snd packing away - does tend to limit my time.
Hope your build continues as well as it is. You will soon have that hull all sealed up.
Tony
goddo
#112 Posted : 11 November 2019 00:08:21
Tony
Thank you Tony. I am very lucky that we have a spare room that I have set up with a wallpapering table.
I screwed a piece of chipboard on top to make it rigid then attached a couple of work lamps.
You are right, it makes a lot of difference if you can just walk away and leave everything where it is.
All I need now is for my wife to decide that she wants to use the space to wrap Christmas presents!!
goddo
#113 Posted : 17 November 2019 19:16:59
More planking progress but I have developed a few "dipped" areas along the way.
Hopefully, once the hull is sanded, the dips will be reduced and the rest can be taken care of with filler.
#114 Posted : 17 November 2019 23:01:45
Hi Goddo, if you change the format of your pics from jpeg to jpg you will find they will show on your posts... Very few will take the time to download pics to view.....
Hope this helps.
goddo
#115 Posted : 18 November 2019 01:20:16
Thanks for the advice Alan. I must admit that you had already informed me of this so my fault entirely.
goddo
#116 Posted : 18 December 2019 21:22:37
A little bit of progress on the hull planking.
I'm hoping to get the final planks on over the holiday and then sanding down will begin.
The "dips" I'm experiencing haven't been too onerous and I have had a go at filling a couple with 0.5mm thick strips and sanding back. It seems to be working at the moment.
Apologies for uploading pics with wrong extensions.
In the meantime, Have a Merry Christmas A Happy New Year to everyone.
z8000783
#117 Posted : 18 December 2019 21:30:57
Groups: Unapproved
Looks good Chris.
I put together a calculator for the last 10 planks you might find useful. Have a look at the link in my signature.
#118 Posted : 18 December 2019 21:52:29
Chris
You are doing so well with this one. Will not be long now before you have that hull all sealed up.
Hope you have a good Christmas and get the time to press on with your build.
Tony
goddo
#119 Posted : 19 December 2019 12:48:48
Thank you for your kind comments.
Just thinking ahead a little, I have some Model Craft flexi sanding sticks of varying grades plus flat sheets of sand paper but wondered if anybody had used or had an opinion on, the Tamiya sanding sponge sheets as offered by Cornwall Boats. Do they offer any advantages at all?
goddo
#120 Posted : 19 December 2019 12:49:49
z8000783 wrote:
Looks good Chris.
Thanks John. That's very useful. I shall download and use this table.
Guest (17)
25 Pages «<45678>»
This page was generated in 1.979 seconds.
