38 Pages «<2627282930>»
Garth's Black Pearl Options
Garth
#541 Posted : 30 October 2019 10:07:22
Hi Tony,
Thank you for the info. Now the tricky bit - to find somebody in South Africa that stocks MR Metal.
Kind regards,
Garth
"Measure twice, cut once!!!"
Finished!!! HMS Victory,
Current build: Black Pearl.
Wish list: USS Constitution.
#542 Posted : 30 October 2019 12:25:26
Garth wrote:
Hi Tony,
Kind regards,
Garth
Garth
Similar in England with it being held by only a few stockists. I ended up sourcing it via ebay in the end.
Tony
Garth
#543 Posted : 30 October 2019 14:35:17
Hi Tony,
As luck would have it, there is a model shop near me that has some. I just need to contact them and find out what their delivery costs are.
Thank you again for your suggestions, they are much appreciated.
Kind regards,
Garth
Garth
#544 Posted : 30 October 2019 14:37:22
Hi All,
Had some more time on the Pearl this weekend BigGrin
Fitted & rigged the main deck guns, as with the guns on the deck below, I used my own interpretation on the rigging. I know it’s by not accurate or even correct, but I feel it looks better than the methods suggested in the instructions. Blushing
The thick thread around the back of the barrel is 0.8mm thread left over from my Victory and the remaining thread is what was supplied with the Pearl.
I also had some brass rings left over from my Victory.
I will add rope coils to the end of the ropes at a later stage.
After that I fitted the Caryatids to the gallery. The pins really helped secure them.
Kind regards,
Garth
Garth attached the following image(s):
skyfire
#545 Posted : 31 October 2019 10:45:05
Looking great!
What did you use to paint the hull ?
#546 Posted : 31 October 2019 14:45:26
That is looking very nice indeed.Love Love
Garth
#547 Posted : 01 November 2019 09:05:11
Hi Guys,
Thanks for looking in and for the kind replies.
Answers to a few questions:
Skyfire; As I was building the hull, I used an alcohol-based wood stain, a dye in fact, to make sure that the black flowed into all the nooks & crannies. Once all the assembly was complete on the hull, I used a matt black craft paint. The brand is Genuine Heritage Craft Products, I’m not sure if it is available internationally. Its quite thick so I thinned it down with water at about a 60-40% ratio – basically until it flowed easily. I then mixed up varying shades of grey that I dry-brushed on. I’m going to add more weathering once all the assembly has been completed.
Malc & Tony; Thank you both for all the effort regarding my brass blackening issues. I have got hold of a bottle of Brass Black. Our local gunsmith gave me a bottle and said I can use as much as I need it. Thanks Vincent from WJ Ritchie.
My first tests were great. After a minute or two the brass & copper turned pitch black!!! Only to rub off on my fingers. Cursing Done some more reading and it looks like the parts will need to be buffed with steel wool and a soak in white vinegar first. I’ll keep you posted.
Not this weekend though. Tomorrow everything in our household comes to a stand-still!!! I’m going to be drowning my sorrows or dancing on the tables – either way the brandy’s going to be flowing!!! Drool Crying BigGrin Good luck to everybody watching the rugby, let’s hope it’s a cracker of a game and cross our fingers that Mr Jerome Garces doesn’t make it all about himself!!!
Kind regards,
Garth
#548 Posted : 01 November 2019 09:16:07
She looks stunning Garth, love your attention to detail....Love Love Love
Sticky Wickett
#549 Posted : 01 November 2019 15:58:30
This is an excellent model Garth. Greta attention to detail. Top notch!
Phil W.
RM1
#550 Posted : 04 November 2019 11:39:00
Hi Garth. pleased to see you're coming right with Brass blackening.BigGrin
( Great game of Rugby on Saturday BigGrin BigGrin )
Malc.
Garth
#551 Posted : 05 November 2019 08:03:21
Hi Guys,
Thanks for the replies.
Thanks Malc, WHAT A GAME!!! Really glad Mr Garces had one of his best games ever.
Kind regards,
Garth
Garth
#552 Posted : 22 November 2019 13:27:27
Hi All,
Almost wrapped up the hull assembly, I’ve still have to make the, stern lanterns, gun rope coils, barrels & crates, figures and the Figure Head. I’ll leave the figure head for last though – it just seems appropriate.
Added all the bits to the handrails, fitted all the deck items, wheel, launches etc. it seems that Hachette have really left us with an awful lot of work in issue 118 & 119.Cursing Cursing Cursing
I made up the anchors. I have saved all the offcut pin heads from the Victory planking; some have found a home on the reinforcing bands on the anchors. They serve no real purpose except to add some detail. Once done, they were sprayed matt black followed by various grey dry brushes. I added some GW Typhus Corrosion followed by a GW Ryza Rust dry brushing.
I added a spare double block and basic rigging as in the Victory instructions. Note though, the block arrangement in the pics is incorrect. I changed it when I fitted it.
The gun port lids followed the same paint procedure. I drilled a 0.8mm hole for the thread. I also kept the off-cut hinges from the Victory’s gun ports. I glued them to the Pearls hull, with off-cut nail heads for detail. They also got the same rust treatment.
Kind regards,
Garth
Sticky Wickett
#553 Posted : 22 November 2019 16:53:34
Great work Garth and i have to admire your patience with this model as you have stuck with it for many years when most would of given up. Nice one!
Phil W.
#554 Posted : 22 November 2019 21:17:31
Garth
This looks better and better each time i see it.
I think you have done a great job on shading the black finish so it has depth and looks "old".
Hope it continues well - not that far to go now :-) although i am sure all that rigging will give you plenty to do.
Tony
#555 Posted : 23 November 2019 00:21:35
Stunning work Garth.…The more you do the more I love this build.... Love Love .. Very well done indeed....Cool Cool Cool
#556 Posted : 23 November 2019 10:11:22
That is looking stunning Garth.Love Drool Love Drool Excellent work.Cool
#557 Posted : 23 November 2019 10:19:29
It's looking really amazing. It would be great to be able to wander around those decks.
Garth
#558 Posted : 01 January 2020 17:52:45
Hi Guys,
Once again thank you sincerely for all the kind & inspiring remarks.
Sorry for the late reply, but we've had a crazy year end at the office & once I went on leave, there were a years worth of odds to do around the house. To compound this, our daughter starts school this year & we have to turn her 'baby'' room into a young girls room.
A belated Merry Christmas & a very happy & prosperous New Year to all those who celebrate itBigGrin
Hopefully I get a day or two to do some work on my PearlUnsure
Kind regards,
Garth
RM1
#559 Posted : 08 January 2020 09:21:25
Hi Garth. A slightly late seasons greetings to you.BigGrin Looking forward to seeing more of the build in the new year.
Malc.
Garth
#560 Posted : 23 January 2020 10:04:37
Hi Malc,
Thank you and the same to you and your family.
Kind regards,
Garth
Guest (14)
This page was generated in 0.256 seconds.
