 Rank: Beginner Level 1  Groups: Registered
Joined: 13/01/2015 Posts: 9 Points: 27 Location: Midrand, South Africa
Hi everyone.
Quick question. When building the RB7, do you need to decide if you want it to be race car or display car? Or can it be both as and when needed? I don't want to start sticking together the display body and then find the panels cannot be removed when I want to race/drive the car.
Apologies if this has been discussed before.
Cheers.
Joined: 23/07/2013 Posts: 120 Points: 336 Location: Brisbane Australia
Hi, A couple of links that may help. https://forum.model-spac...aspx?g=posts&t=8043
https://forum.model-spac...spx?g=posts&t=14471
The same wings are used but main body is changed. And if you go with the display body (as I have) you have to remove the cylinder head for the body to fit?? Chasecar
