Missing holes Bulkhead for Support /Doorstrap Right side door Options
Andreas
#1 Posted : 04 November 2019 19:45:31
Groups: registriert
Hi everybody,
I just found a little problem at the right side door of the Samba bus. In step 81-B the support with strap is screwed into the door trim.
But in the Bulkhead there are no holes for the door strap with support.I attached two pictures to show up what i mean.
Forum Support Team
andali15
#2 Posted : 04 November 2019 21:40:42
Hi Andreas, check part 85 lower front wheel arch, on the inside you will see 2 sets of holes I assume these will be used for the check strap later on in the build. Only my guess though. Andy.
stevy666
#3 Posted : 08 November 2019 13:00:57
Surely the part shown with the holes is not the bulkhead?
This page was generated in 0.219 seconds.
