Your customer service asked me to ask the technical guys on this forum, as they can't help me. They state that you guys can solve my problems, so with hope!! The head on the model doesn't work correctly. It does no calibration on start, and then behaves very oddly in use. I've uploaded a video showing this: https://drive.google.com...q0lbrS/view?usp=sharing
Your customer services want to know what parts they need to send me in order to make it work. Can you please let me know. Regards, Ben Clewett. ****edited by admin to remove sensitive information****
PS I have noticed that if I start it on mains power, it works perfectly, even when mains is then disconnected.
If you start it on battery, it does not complete the head calibration or work correctly afterwards.
But all customer services want to know is what parts they need to replace for me...
Thanks,
Hi Ben, That’s a new one on me. When you initially start him up, I noticed the head did not calibrate. He jolts forward and then should move his head left and right before chirping to confirm he has started. Check the wires, there maybe a wire not pushed in home fully. Sometimes the cables look fitted they just need a little push further. The fact that the head is moving in some parts of the app, I’m more inclined to say there is a loose connection somewhere. As stated the dome moves on startup to calibrate. Keep me posted. Regards Mark BTW, be careful when operating him on deep pile carpet, he has a tendency to topple over. Regards Markwarren (Mark) Admin
Hi, Thanks for getting back to me and suggesting a broken wire. Whilst fiddling with it, I've found I can get it into full working stage, but only by starting it on mains. I've shown this here: https://drive.google.com...vN6z12L08fxXq4wV85vC2ZP
So the fact it can be jump-started to full operation, suggests to me it's not a wire. Also I've spent a long time going over every wire and I can't see one out of place. Have you any idea what's wrong? Ben
I’m wondering if the batteries have been calibrated properly on its initial first time startup. In issue 100 Quote. ”Plug the mains adaptor into R2-D2. Plug the other end into the mains and turn it on. Leave it for a couple of seconds, then turn off and unplug both ends. This is a protection procedure to activate the battery, and without doing this, R2-D2 won’t turn on. You do not need to repeat this process, and in future the adaptor is only used to recharge the batteries. If R2-D2 is turned on, his front the red/blue status light will change colour and flashing sequence to indicate the charge level (see the User Guide for details).” Assuming you have the correct battery requirements, I would re-charge them again in the charger unit and carry out the procedure again as above. It is all trial and error I’m afraid, but it seem to point to a battery issue on startup. Keep me posted Regards Mark Regards Markwarren (Mark) Admin
Hi again,
I followed that instruction at the time, so would not expect it to be needed again? Also it does work on battery, with everything apart from the head calibration. Just that one little bit needs a mains connection.
I'll follow your advise and cycle the batteries a few times, and see if that helps. Currently the R2 reports them 100% charged.
I can also measure the voltage. Do we know what voltage the R2 needs the batteries to be at to work correctly?
Ben
Hi The reason I said it might need calibrating again is because although it works on the batteries,after starting up on the mains, it doesn't appear to start up on the batteries alone. You can test the voltage, if memory serves me right it should read 12-14v. The only other option to try would be to get a replacement battery case with new cables. Regards Mark Regards Markwarren (Mark) Admin
Joined: 25/02/2018 Posts: 8 Points: 14 Location: Port St Lucie, FL
I finished my build the other day and when I turned it on I get the slight jolt forward, Left/Right head turn and the whistle. However the purple light never comes on and the projector light stays on (just the light, no image). Also the lightsaber doesn't eject but R2 makes the noise as though it worked. I'm thinking the issue is the small board in the head that all the lights and lightsaber hook up to.
Sooks569 wrote:I finished my build the other day and when I turned it on I get the slight jolt forward, Left/Right head turn and the whistle. However the purple light never comes on and the projector light stays on (just the light, no image). Also the lightsaber doesn't eject but R2 makes the noise as though it worked. I'm thinking the issue is the small board in the head that all the lights and lightsaber hook up to. Download the troubleshooting guide here. https://forum.model-space.co.uk/...aspx?g=posts&t=32756Regards Mark Regards Markwarren (Mark) Admin
Already did that! The lightsaber issue says it “could” be a connection issue but no explanation about how to troubleshoot the bad component. I would try testing the motor again, but all the corresponding cables are utilized elsewhere in the build.
Joined: 04/09/2019 Posts: 36 Points: 108 Location: Kent, Wa.
You can test the ejector motor separately with a multimeter using the "ohm" setting to see if the motor has an open circuit. My motor was DOA on arrival, it showed an open circuit. You have to unplug the motor to test it.
Joined: 28/12/2018 Posts: 67 Points: 213 Location: United States
Check the wires on the bottom of the light saber ejector mech. Make sure the yellow wires are not snapped off the switch. Rob the wire from ever where it's used and test it. Fred Sooks569 wrote:Already did that! The lightsaber issue says it “could” be a connection issue but no explanation about how to troubleshoot the bad component. I would try testing the motor again, but all the corresponding cables are utilized elsewhere in the build.
