Joined: 20/01/2011 Posts: 608 Points: 1,753 Location: Canberra, Australia
The keel of the Sovereign of the Seas. Still needs two reinforcing pieces to be glued over the joints in the keel.
Added the two remaining reinforcing parts, next up is all the frames.
Work on the frames is progressing.
Bowsprit has been added, but not glued as yet. Still needs lots more to be added to it.
The deck, masts and bulkheads are not glued in yet. Need to find the box of balsa bits first.
Built the castle at the stern this afternoon.
Only parts not glued right now are the 3 dowels for the masts and the beak. The beak is the part sticking out from the bow under the dowel.
Added the wood for the false cannons to be screwed in to.
Added the next deck to the ship at the forward end. Still need to add the rest of deck supports and balsa, (for the centre of the deck supports as they are far to flexible).
Completed the next deck, onwards, upwards and outwards.
Added two more pieces of wood to the castle at the stern.
Painting of the area where the cannons screw in to has finally been done. A second coat may be needed.
Finally another photo of the ship.
Added two more blocks of balsa to the hull, only I left them full width by mistake. Oh well, I will just add full width ones the other side to balance things up.
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,413 Points: 22,549 Location: Northamptonshire, England
Taking shape very nicely, great work. Mark Regards Markwarren (Mark) Admin
Looks like you're progressing very nicely, well done....  .. Am surprised you haven't secured the keel into a build jig, something I would always recommend on any ship build.... Regards Alan
Never had a problem building without one. :)
