Orlop deck planking, what strip? Options
gingerale75
#1 Posted : 18 November 2019 21:36:13
Hi Experts,
Could you please confirm what strip should be used for the orlop deck planking?
Both the instruction and the official build says 1x4mm strip, however there was none supplied until Stage 12.
I believe the correct size should be 1.5x4mm, this was supplied with Stage 12 (132).
Am I right?
Happy building!
Laszlo
Finished builds: HMS Victory, HMS Victory Cross-Section
#2 Posted : 18 November 2019 23:47:48
Other builders that encountered this problem used the 1.5x4mm strips...Cool Cool ..
Hope this helps..
gingerale75
#3 Posted : 19 November 2019 00:49:51
Hope this helps..
Thanks Alan, I thought that’s the correct strip to use, just wanted to double check.
Happy building!
Laszlo
This page was generated in 0.129 seconds.
