19 Pages «<910111213>»
#201 Posted : 20 November 2019 08:47:48
Very nice work Trev, love what you’ve done.Love Love Drool
#202 Posted : 20 November 2019 08:58:30
Well done Trev. It's looking really great.BigGrin
#203 Posted : 22 November 2019 12:25:59
Hi Tony, I did find it interesting as this is the first time that I have worked with Leather.
Trev
#204 Posted : 22 November 2019 12:28:53
Hi Mark,
Thank you for looking, yes I am pleased with the result and there will be a lot more Leatherwork.
Trev
#205 Posted : 22 November 2019 12:37:38
Hi Roy,
Thank you for posting, I think you will enjoy my next stage as the kit has not supplied coach guns, I will be scratch building a pair with covers to place with the saddlebags. This again will involve (as you know) more time but I am well on the way and will post as soon as possible how I built them.
Trev
DaDokta
#206 Posted : 29 November 2019 08:44:24
Those saddle bags look great! Superb build!
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
#207 Posted : 10 December 2019 07:20:49
Hi Walter,
Thank you for having a look at my build, with christmas approaching fast haven't had much time with the stagecoach, but I have started to work on a pair of scratch coach guns which I am finding fascinating.
More soon
Trev
#208 Posted : 15 December 2019 16:58:05
UPDATE:
SHOTGUNS OR MESSENGER GUN.
First model shotguns were not supplied with the kit, so I decided to make a pair to fit alongside the saddlebags, this involved a search to find a picture plus information about how it looked and worked.
A Coach-Gun or Messenger was a double-barreled shotgun generally with barrels about 18'' to 20''ins long and placed side by side to be used for defence, and guard express shipments what surprised me was they were 10 and 12 gauge and used Black powder which will take a lot of time to reload.
First I made a Master pattern this will be made from plastic so if I needed to remake they will all look the same, to do this I cut around the paper shape and stuck it to a piece of plastic then carefully cut around it filed and sandpaper to shape.
Draw around the pattern on to a piece of wood (this is 5mm Oak) and keep as close to the black line to save file work.
I am making two guns so the next job will be to stick and clamp them together, I did this by using double-sided sticky tape and a spot of glue each end.
When dry remove from clamps this is the time to check for splits and faults marks and dents, also time to file and shape to look like one gun.
Sand both sides on flat sandpaper I needed a coarse grade to smooth Oak.
Next was to remove wood from the fore-end of stock to accept both barrels this is why I chose Oak because of its strength.
More work on the stock shaping and sanding and filing.
This I found interesting dip the stock in wood dye I used American Walnut this enhances the natural grain of the wood, also you can see I have started to fit the trigger and guard made from 1mm brass wire.
This is up to date now, next will be the making and soldering of the barrels.
Trev.
#209 Posted : 15 December 2019 17:09:11
Drool Drool Drool
Amazing detailing Trev.
Keep up the good work. Cool
#210 Posted : 15 December 2019 17:54:20
Very neat work Trev.
Tony
#211 Posted : 16 December 2019 08:08:03
Many thanks for looking Derek, well that's the stock's done now on to the metal barrels.
Trev
#212 Posted : 16 December 2019 08:14:21
Hi Tony, carving those stock took time, I carved 5 to get close to the picture, I am always learning. many thank's for looking in.
Trev
eebygum
#213 Posted : 16 December 2019 08:44:19
Nice work on those guns well done
Terry
#214 Posted : 16 December 2019 09:32:10
Really great stuff there.
I just love what you're doing.
Roy.
#215 Posted : 16 December 2019 17:21:53
Really nice piece of scratch building there Trev, very well done....Drool Drool
#216 Posted : 17 December 2019 07:33:40
Hi Terry, thanks for your comments I see you have built the Stagecoach, I was wondering how you got on with it and did you find it a straight forward to build.
Trev.
#217 Posted : 17 December 2019 07:52:32
Hi Roy,
Bit more scratch today, I am trying to make both side plates from brass plate, that is the part that is covered with engraving but on this type of gun it will be clear but sprayed to match barrels, also a pair of hammers to fit behind the breach should be fun.
Trev.
#218 Posted : 17 December 2019 08:04:00
Hi Alan,
Raining all day today in Sussex just the day for modelling and cup's of tea's, as I said to Roy today I will be trying to make and fit side plates and hammers to the guns, the hammers will be made from 1mm brass rod heated and hammered to shape, fingers crossed it should show some sort of shape to represent the picture I have, time will tell.
Trev.
tnequette
#219 Posted : 17 December 2019 20:10:21
Trev,
Have been following you from the start. Wonderful work and I have high hopes to try it. My request: could you share your sources or pics of the actual rifles here in your build. May help a few of us aspirants.
Merry Christmas,
Tom
#220 Posted : 17 December 2019 22:29:14
Hi Tom,
Thank you for looking in, I found all the information on Wikipedia tap in Shotguns Wild West or Coachguns 1885 or Messenger's Gun that should be ok, there you will find a picture and early manufacturers.
Trev
Guest (12)
This page was generated in 0.343 seconds.
