 Another mad decal fest from GoodSmile Racing this one being the 2014 winning BMW Z4. Its a Fujimi kit so engine just the cockpit. The sprues all look good with minimal flash if any present, the main upper body and floor pan are well detailed and the main body has minimal seam lines to clean up. The wheels are well molded and look good. The instructions are Fujimi's usual fare although on the paint list the last colour is indicated but is not named but its easy to work out its semi gloss black. The decals look good and have there own instructions provided. Aftermarket stuff bought was the Hobby Design etch set and Zero paints window mask set. arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,277 Points: 22,138 Location: Northamptonshire, England
Looks another interesting build Andy, look forward to this. Mark Regards Markwarren (Mark) Admin
Am sure this will be another stunner from you... Look forward to seeing it come together..... Regards Alan
 Thanks for your comments both. Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,700 Points: 17,252 Location: ipswich
Another weird and wonderful paint scheme. I bet it turns out great!
Roy.
 Thanks for looking in and your comments Roy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Chassis has been painted semi gloss black along with several other parts. The chassis gearbox was painted aluminium and the exhausts painted with oily steel. the brakes/discs were painted aluminium and steel then black panel washed to bring out the etch detail. arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 The cockpit tub has been painted and various parts added along with the roll cage. Some etch added to the front. The upper body shell has been assembled by adding side panels and the bonnet air scoops. After a clean up the first coat of undercoat has gone on. arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Nice work Andy, coming together very nicely. Mark Regards Markwarren (Mark) Admin
 Thanks for looking in and your comments Mark Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Started at the front with the decals. A word of warning if your contemplating building this kit Fugimi decals are thin and delicate, you will be ok if you lay them so you have minimal movement to get them in place. They dont take well to decal softener either so use it if at all in small amounts, take your time and be very careful. arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi looking good, do like the decal scheme on this one cheers mick Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
 Thanks for looking in and your comments Mick Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
You’ve definitely mastered those decals, looking excellent. Mark Regards Markwarren (Mark) Admin
Excellent work Andy, another stunner in the making..... Regards Alan
It's looking great - once again. You'll soon have a whole fleet like these. Superb work.
Roy.
 Thanks for looking in and your comments everyone Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 All the major decals are now done just some small ones to add here and there. arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Beautiful work Andy, going to look great when finished. Mark Regards Markwarren (Mark) Admin
Guest (7)
