80 Pages «<6263646566>»
Sticky Wickett
#1261 Posted : 15 November 2019 19:18:38
This photo shows the end of the decking.
Sticky Wickett
#1262 Posted : 15 November 2019 19:22:17
I'm pretty happy with the way the decking has turned, It's blended nicely and has a 'worn' look without being over the top.
Thanks for looking in, have a great weekend, weather permitting and happy modelling!BigGrin
Phil W.
#1263 Posted : 16 November 2019 00:06:29
Decking looks amazing Phil, so very authentic.... Superb work....Love Love Love
#1264 Posted : 16 November 2019 09:25:24
That decking looks amazing Phil. The weathering is spot on.Love Love Drool Drool
#1265 Posted : 16 November 2019 09:48:19
BigGrin Deck looks good to me and nice work as always Phil
Sticky Wickett
#1266 Posted : 22 November 2019 08:36:08
Thank you very much Alan!BigGrin
Phil W.
Sticky Wickett
#1267 Posted : 22 November 2019 08:36:41
Thank you very much Mark!BigGrin
Phil W.
Sticky Wickett
#1268 Posted : 22 November 2019 08:37:13
Thank you very much Andy!BigGrin
Phil W.
Sticky Wickett
#1269 Posted : 22 November 2019 08:40:07
Good morning from 'The Dockyard'.
To start this post i've included some photos showing the conning tower in situ.
Sticky Wickett
#1270 Posted : 22 November 2019 08:41:06
Front view.
Sticky Wickett
#1271 Posted : 22 November 2019 08:42:09
From above.
Sticky Wickett
#1272 Posted : 22 November 2019 08:42:41
Looking forward.
Sticky Wickett
#1273 Posted : 22 November 2019 08:50:42
Now it's time to start working on the internal details. I'm starting with the aft torpedo compartment which requires lots of scratch building and will take several weeks.
The first job was to study photos of the real compartment on U995. This took a whole evening as I familiarised myself with all the equipment.
I started with making the rear torpedo tube and door. The aluminium tube was a left over piece after i finished installing the torpedo tubes in the bow back in 2016.
The door was made up of several layers of plastic sheet, glued together and a whole drilled through so I could fit a shaft. See attached photo.
Sticky Wickett
#1274 Posted : 22 November 2019 08:52:35
The shaft allowed me to fit it to the chuck on the Dremel, itself being mounted in a mini vice, so I could use it like a lathe.
Sticky Wickett
#1275 Posted : 22 November 2019 08:54:04
I could then shape the torpedo tube rear door to a profile using files and sand paper while it span around in the chuck.
Sticky Wickett
#1276 Posted : 22 November 2019 08:55:11
The next job was to make the hinges. I used plastic rod and sheet off cuts to fashion the shapes.
Sticky Wickett
#1277 Posted : 22 November 2019 08:56:13
A different view.
Sticky Wickett
#1278 Posted : 22 November 2019 08:56:53
From another angle.
Sticky Wickett
#1279 Posted : 22 November 2019 08:59:00
I then made the locking lever and fitted an after-market, etched brass valve hand wheel to represent the drain valve.
Sticky Wickett
#1280 Posted : 22 November 2019 09:00:03
A different view.
This page was generated in 0.425 seconds.
