Making lovely progress, all looks good.... Regards Alan
Joined: 20/01/2011 Posts: 608 Points: 1,753 Location: Canberra, Australia
Decided it was about time I had a photo of the wiring in the dome for R2D2. Maybe not the best way, but it all connects up.
Waiting for the camera battery to charge up, so I can unload the latest photos.
Lower frame is now complete.
Speaker has been added to the rear body panel.
Next lot of parts have been added to the lower frame.
Third body panel has been joined to the other two. Not sure if this is the way to join the body panels to the framework.
Coming on very nicely.  You have the idea on how the body fits the frame, but you've still got a lot of the framework to do first. The legs and bottom sections get attached before the two main body halves. Mark Regards Markwarren (Mark) Admin
Middle ring has been added to the lower frame. Couldn't help adding the body panels again, to see how it all looks.
First of the front body panels is done.
Run out of screws needed to attach the lugs for joining the body panels to the top of the tool box, also the flanged screws I have are too long to attach the other two lugs.
Otherwise things are still going ok.
Latest bit of work on R2D2. Wiring in the dome is all done for now!
Managed to get the lugs for joining the panels together added on after using a smaller screwdriver for the flanged screws and pinching two screws from the bottom of one of the feet.
looking excellent, I can see the finishing line. Mark Regards Markwarren (Mark) Admin
Picked up issue 79 yesterday, photos coming soon.
Another bit of frame has been added to the middle ring. One ring to go.
Looking good, nice work. Mark Regards Markwarren (Mark) Admin
Just had to see what he looked like with the dome on top.
Latest bit of work has been done, with two more sensors added. Along with some more opening parts,
