Orphan greebles - guidance needed Options
x_dfo
#1 Posted : 02 December 2019 02:15:19
Rank: Advanced Member
Hey peeps,
I'm nearing the end (I still can't believe it) and I found some pieces in my spare bag that, after googling and scouring the issues, I can't figure out where they belong.
Thanks in advance!
#2 Posted : 02 December 2019 13:08:46
Stage 85 and 99 should help you with at least two of the parts.....
#3 Posted : 03 December 2019 09:03:24
The first triangular part attaches to the left hand mandible at the rear near the main hull. The last part goes on the underside of the hull, the opposite section to the ramp.
I’ll try and find exactly the other two parts when I’m back home if you are still stuck.
x_dfo
#4 Posted : 03 December 2019 18:52:00
These two marked '?' have completely eluded me. Your time is much appreciated (all of you)
x_dfo attached the following image(s):
#5 Posted : 03 December 2019 20:45:37
Build stage 24 for another one....
#6 Posted : 03 December 2019 21:32:27
The bottom one on your picture goes on the underside of the hull, here in the picture circled and arrowed in red. It goes into the two holes as shown.
x_dfo
#7 Posted : 03 December 2019 22:03:04
Thanks so much!
#8 Posted : 03 December 2019 22:09:32
The other part is found and fitted here as shown in issue 99. Part 5, fitted in stage 7 in the mag as shown.
x_dfo
#9 Posted : 04 December 2019 20:39:36
Many thanks to you all, super helpful!
This page was generated in 0.234 seconds.
