There was a problem ! Scroll mechanism when opening and closing the manipulator ! And the bottom somehow twitches at the same time all and when you open it comes to the stop and begins to scroll and when you close the same ! ??? Tell ME what to do what is the problem ? Opens all the way and closes then starts to scroll !
Your mechanism for the arms don’t look right, here is a picture of mine for reference. Mark Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
It doesn't read the code so I can't connect to Wi Fi? What to do? 20 minutes of sitting , even the lens removed ! But on direct connects video shooting and photo goes! So the camera works...
Joined: 20/01/2011 Posts: 608 Points: 1,753 Location: Canberra, Australia
Zuy9o wrote:It doesn't read the code so I can't connect to Wi Fi? What to do? 20 minutes of sitting , even the lens removed ! But on direct connects video shooting and photo goes! So the camera works... What have you tried to get it to read the code ?? As in changing light conditions and moving the code closer or further away from the lens ? Also have you tried looking at the R2D2 troubleshooting guide ? https://forum.model-spac...aspx?g=posts&t=32756
Yes, moving away and approaching ! no result . And not only I have in group already man 6 wrote about this . Indeed there is no here on forum !
A thread where someone had a similar problem and they ended up getting in touch with C/S for a new pcb card. https://forum.model-spac...aspx?g=posts&t=32738
