 All looking good and nice work Mick Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Great work Mick, coming together very nicely. Mark Regards Markwarren (Mark) Admin
Lovely work Mick, coming along beautifully.... Regards Alan
Hi thanks to all who looked in and left comments, after bit of delay in delivery's why hachette move there warehouse, got few more issues Issue 39 This just another hull plate with the black and white stripe, just screw it in same as previous plates. mogwai attached the following image(s): Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Issue 40 First of all fix the label to the searchlight led cable,then thread the searchlight Base onto cable making sure it's the right way round, fit the searchlight lens into the body,fit the led into the searchlight back,again make sure it's in the rail get way up.then glue the back onto the body,clip on the searchlight support, then attach the arm and glue this to the support, then slide up the Base and glue this to the bottom, then thread the wire through the searchlight Base deck, glue the deck to the platform, then glue on the searchlight, then add locker structure to the deck behind the searchlight. Next glue together the 2 half's of the upper superstructure, glue a ladder to one side of this. Then glue the searchlight platform to the upper superstructure. Then retrieve the radar assembly from previous issue and glue on the few bits of etch to this,and finally glue on the 4 zag artillery guidance devices making sure they facing the right way.cheers mick. mogwai attached the following image(s): Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Issue 41 Just the same as issue 39 but attach hull plate to other side. mogwai attached the following image(s): Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Issue 42 Again just another hull plate to start extending the next section of Hull, that's it for now. Cheers mick. mogwai attached the following image(s): Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Lovely update Mick, she's coming along beautifully..... Regards Alan
Hi thanks to all who looked in and left comments much appreciated. Issue 43 First of all fit the 2 small gratings on to the 2 larger ones then glue these to the side of the admirals bridge deck.attach the sticker to the light bulb cable,then fit the bulb into the windows,then assemble the 2 sides and front to the window,then hold all in place with the deck on top of it.then bend the 3 bits of railing and glue these to the deck.then glue this assembly to the deck,then glue on the searchlight assembly from previous issue to this.then glue the 2 shelters to the deck at the rear.cheers mick. mogwai attached the following image(s): Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Issue 44 First of all glue the deck onto the upper mast deck.and glue the 2 half's of the conning tower together.then glue the conning tower to the deck.paying attention to which way round it goes it has 2 holes in one side which need to be on the right hand side.then glue the 5 bits of etch together that make up the ammunition hoist,then glue this to the deck at the front.then glue in 3 lockers around the conning tower,I had to cut bit off bottom of tabs for these to get them to sit on deck flush.then a further part is glued in those 2 holes mentioned before. Then glue in the 2 bits of preshaped handrail.we also get 2 replacement anchor rings, I not put mine on yet as I'll have to remove anchors to paint the red portion of deck. Cheers mick. mogwai attached the following image(s): Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Issue 45 First of all glue the 2 rangefinders onto the admirals bridge deck, then glue in 2 signal lamps.then glue in 2 loudspeakers one each side.then bend 2 bits of handrail and glue on the grated portion of deck. Then there's 2 bits of preshaped handrail. To go on the small platforms where the rangefinders are, mine just needed small squeeze in to fit properly.then there 2 platforms to bend and fit under the admirals bridge deck. Then glue in the angled ladders one each side.then there are 3 antenna supports to glue on. Then glue the admirals bridge deck assembly to the upper mast assembly,I had to trim the rear tabs to get this to seat properly. And just put the tops of the angled steps into holes of deck above them. mogwai attached the following image(s): Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Issue 46 After the previous 3 fiddly issues it's nice to have a simple one Just another hull plate to fit,then final pic of what we have so far. Till next time cheers mick. mogwai attached the following image(s): Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Nice work Mick, you seem to have a knack with these battleship models! Well done.
Kev  Per Ardua Ad Astra
Hi thanks to all who looked in and left comments much appreciated, on we go. Issue 47 First of all we attach 2 more the yellow liferafts, then glue in 4compass 2 on the admirals bridge and 2 on the foretop gallery, then it's bend 2 more bits of handrail one fixed to each of the fore mentioned assemblys, then there are 3 circular rails to glue to the conning tower.then 2 more bits of handrail are glued onto the admirals bridge. Then we fit the foretop gallery to the admirals bridge. Then it's make up to ladders, now here is an error to say the least in the instructions, they built them the wrong way round ie the back of the ladders face the front,I just turned mine around so the steps looked right unfortunately this puts the location pins on top of the ladders instead of at the bottom where they should be, so I cut these off, anyway looks better this way, even though they end up not locating in the holes in decks anymore.hopefulpy if any more ladders they get them the right way round from now on.Then there are 3pipes to be fitted to the rear of forward superstructure. Cheers mick. mogwai attached the following image(s): Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Hi forgot to upload pic of 3 rails on conning tower.cheers mick. mogwai attached the following image(s): Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Issue 48 Here we just get another bit of deck,just simply screw to previous deck,cheers mick. mogwai attached the following image(s): Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Issue 49 Here just another hull plate to screw on. Cheers mick. mogwai attached the following image(s): Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Issue 50 Another one that will test your modelling skills to the limit,stick a label on the motor cable.cheers mick. mogwai attached the following image(s): Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
 Coming together nicely Mick. Your really cracking on with this one
Beautiful work Mick, really coming along very nicely indeed.....  … Especially love your label attaching skills..... Regards Alan
