Here is Tamiyas 1/24 porsche jagermesister.Unlike its bigger brother that Andy building this is a curbside kit. I have started priming the major parts and assmebling the very simple cockpit. many of the parts are a very bright orange so it is taking quite a few coats of primer to cover it up. If you are not careful the underlying orange color may bleed through the white decals.This will be my first attempt using Zero paints and clearcoat. These paints are hard to get hold of in USA at the moment. Carl darbyvet attached the following image(s):
Looking forward to seeing this come together.  Another one that’s going to need shades. Mark Regards Markwarren (Mark) Admin
 Hi Carl It's a nice kit by All reports you could get a sheet of white decal paper and cut backing decals to stop the bleed through of the paint. Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Looks like this will be an interesting one to follow Carl, good luck with the build.... Regards Alan
