 All looking good and nice work Phil Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Brillisnt work Phil. I had been so taken with the outside parts of your build i had forgotten this thing has internal features. Some really neat scratch building you are doing and impressive. Tony Happy Modelling
arpurchase wrote: All looking good and nice work Phil Thank you Andy! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
birdaj2 wrote:Brillisnt work Phil.
Tony Thank you very much Tony! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
 Impressive stuff, as always Phil
Good evening from 'The Dockyard'. Well it's been a couple of weeks since my last update. Last week I decided to have a few evenings off from modelling and this week has been spent doing research. I'm currently in the process of fitting out the aft torpedo compartment with it's myriad of pipes and valves. I won't be able to replicate all the plumbing as this build would take 20 years  , so it was a case of working out what to make and what to leave out. This was how i spent Monday and Tuesday evening. Wednesday i made a start, concentrating on the larger pipes first. Using 2.0mm diameter round acetal rod, i soon found out that it doesn't like bending around corners, even when dipped in boiling water. I then tried 2.0mm diameter brass rod and found this metal too hard to work. I then realised the best material to use is solder; flexible, easily bent, doesn't snap and will take paint. So after a couple of hours trial and error last night and getting nowhere fast with the plastic and brass, i ordered a reel of 2.0mm diameter solder today. Consequently, I haven't made lot of practical progress this week, which is always the case when conducting research. Although i did make two housings for this pipework to fit into on the top and side of the torpedo tube as seen in the attached photo. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
The attached photo shows the aft torpedo compartment of U995 and all of it's pipework! Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
That concludes the update for this week and hopefully a bit more progress will follow next week. Thanks for looking in and your comments, have a great weekend and happy modelling! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
CaptnBirdseye wrote: Impressive stuff, as always Phil Thank you very much Gray! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Nice work Phil  , see you are going have your work cut out. Mark Regards Markwarren (Mark) Admin
You may not be able to fit all the pipework and plumbing Phil but am sure what you do fit will look absolutely amazing, look forward to see it all come together..... Regards Alan
Markwarren wrote:Nice work Phil  , see you are going have your work cut out. Mark Thank you Mark. Yes mate, it will take a little time. The trickiest part is formulating a working method and technique that is repeatable. Once I have that solved I can apply that to all the pipework that I make and not spend longer than required to get the job done. Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Gandale wrote:You may not be able to fit all the pipework and plumbing Phil but am sure what you do fit will look absolutely amazing, look forward to see it all come together..... Regards Alan Thank you very much Alan! I'm hoping to convey the sense of complexity without replicating everything verbatim. I mentioned to Mark, it's about solving the technique and working method to be able to repeat consistently. Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Good evening from 'The Dockyard'. A little more progress this week making pipework. Lots more to do but it's a start. The attached photo one of the largest diameter pipes made using 2.0mm solder and M2 washers as flanges. I made the valve body from plastic strip and drilled a 0.8mm diameter hole in the top to accept a piece of bent brass to represent the valve handle. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Painted. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Fitted. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
I then made a smaller diameter pipe using 1.2mm diameter solder. This section has two valves and was a tad tricky to fit. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
I also applied a black wash, but looking at the photos it requires toning down a bit; nothing a cotton bud dipped in thinners can't sort. Well that's the update complete for this week. With the holidays soon upon us, my next update will be at some point in the next week and a half [ish]! On that note i would like to wish everyone a very Merry Christmas! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Guest (9)
