Diamensions of plastic Options
#1 Posted : 22 August 2011 21:36:27
Mr T
In your official build you mention using various plastic parts to enhance the model,The peices im asking about are the dimensions of the deguasing strip,rudder enhancements and the strip used around the boat deck grating.As iv decided to follow your lead on these as i agree it improves the models overall appearance,its probably several months before i will need them but stocking up never hurt anyone
Thanks
#2 Posted : 22 August 2011 21:51:29
1mm wide x 0.5mm thick and as long a length you can find.
Its certainly easier to fit than brass wire and is also the right profile shape. you could also add the bracket mount straps to it with some fuse wire if you want to go that far.
#3 Posted : 23 August 2011 00:22:55
Thanks Mr T
For the swift reply il get onto it straight awayBigGrin
This page was generated in 0.903 seconds.
